Front terminal battery PSA
Washington
As stupid as this sounds if you’re running a battery with the posts at the front make sure youre checking the battery hold down frequently.
For background I have had this same battery in the truck for 4+ years without issue but for some reason today the battery hold down moved slightly, crossed both terminals and almost burned the truck to the ground. Well not really but it did release a scary puff of smoke from under the hood before the j-bolt melted in half!
Check your battery hold downs or maybe even put an insulator between it and the terminals.
PS you feel like a real dumbass when you have a bunch of people in your car that you make jump out on an on ramp because there is smoke coming out from the hood.....:bang:
Time for Military Style Terminals?
Batteries going to Ground is scary!
Yeah military terminals would be nice but I still think the shape of this battery puts the hold down bar too close to them. I think the hole in the battery box that the passenger side J-bolt goes through has been “tearing” slightly because the bolt appears to be pulling through the battery box some. I think time to rethink the way this type of battery is held down or go back to a stock terminal placement battery (which I assume is in the rear).
The battery I picked up years ago had both top and front terminals. It had black and red plastic plugs for the fronts that had to be removed for use. Maybe find some of those somewhere and just cap them off ? ? :meh:
Correct being Toyota non sealed? I have seen issues with rust in hoods from non sealed batteries, no issues?
They still make the correct battery and they aren't that expensive?:hillbilly:
Do you have a picture of your setup?
Exactly why I dont use the factory set up. Toyota corrected the problem with the 100 series similar to what I use today.
The correct battery is a group 27F, your choice of type. I run an Interstate Megatron, but most we work on run Interstate blems, we get them for $25. Almost all that we work on run lead/acid, have never seen hood rust, but we don't have rust issues here., the rust buckets we see are imported.
I ran unsealed lead acid batteries for years. Then I was getting Optimas for free because Interstate Batteries was a client of mine. When that dried up I bought regular lead acid Interstate Batteries Group 27F (one cranking, one marine). After about a year with the cranking and 7-8 months with the marine I can say I've never seen anything like this. They leaked and caused the hold down bar to rust. Not the hood itself but still.
I run a Deka Group 27F AGM in my 92. I will be going to Deka Group 31 AGM in my 93 shortly.
Good PSA - similar thing happened to me last week! Battery hold down had completely given up and battery was just flopping around in its tray. Completely broke the terminal end in half! Had to get towed out of the woods, lesson learned...and I always carry spare terminal ends now too.
Carry a spare or just go without and no longer worry about it;)
Agree that lead acid takes a bit of simple maintenance and it's likely too hard for some. But you reportedly pressure wash your rigs and undercarriage every week, but cant be bothered to spill a bit of that water on the battery once in a while?
Batteries should get distilled water and better would be electrolyte (sulfuric acid diluted to the right specific gravity with distilled water)
Oddly enough, the 200s (at least the LX570) has exactly the same configuration as the 80s.
When I was looking at parts diagrams, I was surprised to see four nuts listed, two per J-hook. I think that people are losing the second set and applying more tension to the hook than it's supposed to have. I know mine only had one nut per hook, and the battery box is tearing.
