Front swaybar quick disconnects revisited and tested
I do appreciate the feedback. The big vendors claim ever 80 is a little different. I do try to cover everybody.
I should take this time to compliment you again on the product though, I did the first day with them in and the next couple of days with it out and what a difference it makes. its not that you get that much more flex its more like turning off physics in terms of body movement. you still move around but over undulating terrain you would be hard pressed to guess whats going on under your butt with how smoothly the axles transition.
Thank you:cool:
hey landcruiser phil, would these front sway bar disconnectors fit on to a 100 series? would love to get some for my car
*FREE SHIPPING* on everything on our site including Swaybar Disconnects.
One of the best off road improvement for the dollar available!
Most 80's see wheel lift here pictured below but not a problem with front swaybars disconnected.
Will these fit a 105?
The same question came up recently with another 105 owner. After several email we decided they would work. I sent a set out and have not heard back assuming they fit fine.
The two factory 8mm holes directly above the front axle is where they bolt. If you have the factory taped holes you should be fine.
Try McMaster Carr, they carry everything! Shipping is super fast too.
Order placed. Assume they are in stock?
Yes, Always in stock and normally ship the same day ordered, as long as Im in town:)
Will ship today Priority Mail
Thanks Andrew for the order
Just ordered mine. Can't wait to get them on and get on the trail.
So, these will work if I weld them in place?
Yes absolutely
A couple good tacks in the bracket holes should be all one needs. Let me know if you order and I will send you the exact bracket placement.
