Front Axle Damage
Lake Mathews, CA
Ok, first off, I'm a newbie to the Toyota 4x4 world. Had a Sidekick that did Everything, except get returned after being stolen. Anyway, I've got a 1991 with 190k and all was fine and dandy with it, only have had it 3 weeks, until my son took it out with some friends he comes home and the cast iron lateral link on the passenger side is in a u shape. I replaced the link and drove it, to alignment shop. They did alignment truck seem ok. But, now it's leaking fluid from the diff 3rd member and also passenger side knuckle. So I tear down the entire axle figuring I'll repacjvand replace seals. Driver side axle tear down, no problem. Passenger side was ok until it came to removing the axle itself. It would not come out. Rigged a slide hammer with a 15 lb weight and after slapping for about 20 min it came out. There was damage to the diff drive splines. So I get new axle. No I'm putting it back in and it keeps going in at an angle. No matter what. It spins the spiders no problem but it's and an angle in the housing. I didn't pay attention when pulling it if it was at an angle when tearing it apart. So my question looking at the spline damage of axle, do you think that a bent axle housing could cause this damage. Any and all replies are greatly appreciated.
If you hit the front hard enough to bent the trailing arm then bent axle housing?
Most likey the housing is bent. Have seen it happen often when frontal impact affects axle position relative to frame. Unlocked axle housing should not be hard to find in California.
The picture is the spline damage.
Yeah your son needs an alignment, up side his head he drove that thing like GTA ( ask him if he was driving like GTA ) oh and you need a new front axle complete . Oh yeah welcome :flipoff2:
Kid definitely hit something. Hard. I'd think getting him to own up to that is a bigger issue than the axle.
A sidekick did everything???
Longitudinal....
Steel not cast iron
