Front Axle Click While Turning
Where do I add grease to knuckle?
The grease port plug is the only square-head bolt on the axle assembly (maybe the entire truck?). When removed, the hole is just large enough to stick the nozzle of a grease gun in.
Gotta have those shameless plugs.......
The shameless ones are the diff fill plugs that are found to be stuck AFTER the drain plugs are removed. :)
If you don't own a grease gun, you can buy a hand squeeze tube of CV joint grease at the auto parts store. Put about half the tube in each side.
I use a long cable tie as a dipstick to see how much grease is in the...
I wish I had a fiberscope to look around inside..
Like @L8Shift mentioned, really is best to drop a zip tie / chopstick / welding rod down that pipe plug you pull & dip the level before adding 1/2 tube grease.
While a 1/2 tube per side isn't much really, too much is worse than too little grease, esp if some PO packed the snot out of the axles & that helped the wear.
The pipe plug is really a true plumbing pipe plug, like what you see on peoples' sewer gear for RV's (obviously just smaller, threads in & out just like any auto bolt.
Grease is whole seperate discussion, but a moly fortified grease is the right flavor to add.
Nothing but black and gooey in there. Moly flings all over the place when you are dirving.
If a person can bend one of these axle shafts while doing a rebuild they are doing something seriously wrong
When you've been around as long as i have, you'll find out anything is possible. Case in point, i worked with a kid in a machine shop once, who found a way to break the dam horn off a 140 pound anvil, now just think about that!!!!
