Front amp replacement help
1996LC So my front amp is fried.... I have a sub and amp in the rear. I want/need to keep stock head unit as I live and park in Brooklyn NY, I would like a new small amp for the 4 door speakers.
hopeful goals
fit in stock location (i can make brackets and mounting solutions)
use some kind of harness to avoid a complete rewire of speakers or head unit..
Mount the amp under the seat unless you think it will fit in kick panel (it won't).
Second under the seat -
Here is what I have powering sub (bridged mono)
http://www.amazon.com/MBQUART-NA180-2-Nautic-Amplifier/dp/B00DJ6775I/?tag=ihco-20
ie=UTF8&qid=1458578307&sr=8-1&keywords=MBQUART+NA180.2+Nautic+Amplifier
(yes it is a marine amp = but $80 for a 2 channel sub amp - not too shabby)
size - 8.9 x 9.4 x 2.2 - fits snuggly - total out of site....
bF
My Sub is allready installed(and working great) in the rear quarter along with the subs amp. Im looking a sulition for the 4 door speakers.
used one of these on a previous project, and for the size, they sound great!
Picasso Nano | Soundstream
not sure what the dimensions are on the one int he dash, but that one MAY fit...
I guess my biggest question is in the wiring department... previously I had issues with the sub amp not turning on unless i pulled out speaker input wire out and in..then it was on....that aside what type of wiring do I need to from from an aftermarket front amp to the stock head unit.... and still send signal to the rear amp/sub
Just source a used factory amp...shouldn't be hard to find and it would solve your wiring issues
Just get a modern head unit... most if not all have plenty of power bypass the stock amps and rock on... I did replace the rear stock sub with a real woofer and a small amp.. it sounds awesome
hopeful goals
I have a factory sub that works that you can have for 15 plus shipping. If you don't want that, I recommend a Kenwood compact amp. I have one installed in factory location with no problems.
What sub and amp are you running? I am getting nothing from factory sub and want to figure out why and if I can put better sub in factory spot.
I have an earthquake sounds shallow woofer 6.5 in factory location and it sounds pretty good. Also have the same speaker for sale, 25 plus shipping.
