Fox vs OME shocks
What FOX shocks are being compared to what OME shocks? Any model # reference? Thanks
2 notes ..
1. I would like to see 3" - 5 " for the front ( or just plain 5" but I need longer shocks for front )
2. Not an easy job to compress those brand new FOX under the truck without lifting it ..
FOX / OME comparo
Yeah I'm curious as well as I'm revisiting my OME Nitro's. Pretty lackluster if you ask me, but I don't have much to compare them to
Per the OP, the only Fox that are in the price range of OME are the Fox 2.0 shocks.
Part Numbers per Fox Website:
Toyota Land Cruiser 80 Series 4WD 1997-1989 Front 1-2.5" 985-24-070
Toyota Land Cruiser 80 Series 4WD 1997-1989 Front 3-4" 985-24-076
Toyota Land Cruiser 80 Series 4WD 1997-1989 Rear 1.5-2.5" 985-24-073
Toyota Land Cruiser 80 Series 4WD 1997-1989 Rear 3-5" 985-24-087
I wonder why they don't make one with a remote reservoir? I would think such a heavy truck would benefit from the extra cooling and oil capacity. My OMEs get too hot to touch on a long drive on desert roads with washboard and typical rocky surfaces.
Stock LX450. OME med duty shocks and springs with steering stabilizer. Purchased kit from Slee with castors. Replaced factory suspension. Day and night difference - ome manages agressive city driving very well. Off road - bombs down washboards, dips, twists and turns with ease. Slow articulated driving is just as good. Snow, sleet, rain - handles surprisingly well with current ome med 2.5" - geolander tires. Assume Fox can be "dialed in" and reservoir serves a purpose long duration washboard speed drives. Never touched shocks to feel if hot after extended offroad drive. Never had fade. Suspension is 2 yrs old
My butt will fade before the shocks do in my opinion. Mine don't take well to washboard, which is common in the areas I bird hunt etc. as I said, my OMEs are just okay. I had a Tacoma and a Jeep with Fox shocks, and those roads were butter smooth. I have heard good things about Icon.
Any of you guys know if I can install the Fox 2.0 IFP shocks noted above before I upgrade my springs? I'm kind of thinking stock height or maybe a max of 2" lift, I'm still undecided as the biggest tire I want to run is a 285. I just purchased my '93 FZJ80 last week and with 177k miles on the factory suspension 2x of the 4x shocks are blown and need to be replaced asap. I'm not sure what springs I want to install yet so it is still sitting on the factory springs. The Fox table states 1'-2.5" for the front and 1.5"-2.5" rear so I have to assume NO:bang:, but I thought I would check in with you guys just to be sure.
You need to chat with @sbman he just did exactly what you are wanting. He did Fox 2.0 with stock coils or OME stock replacement with some coil spacers to keep the coils retained 10" travel....etc. Just click his name & send him a PM.
I'm running 285/75 Duratracs with OME 2860 front, OME 2851 rear and Fox 2.0 Performance Series Shocks. This is a very moderate lift, I would suggest you do the springs at the same time as the shocks, you will not regret it.
285/75 tires with stock springs and shocks, 285k miles on them:
285/75 tires with OME springs and Fox shocks:
After settling and minus cladding:
I did do a fox install with stock coils. It wasn't an off the shelf fox though, none of those would fit without bump stops because they require eyelet to stem conversion. :( I had them built by Downsouth Motor Sports using a 10" stroke Fox 2.0 body with reservoirs and 8 click adjustable dampening. I had to drop my sway bar 1" and add a 30mm coil spacer to keep tension on the coils at full droop. Uptravel remains the same. I'm very happy with the result. I run 285s and did not have rubbing even with the stock suspension, or after the Fox install. With the weight I've added up front recently (winch, battery, etc...) I am planning to get some stock height OME springs to get things back up where they belong.
Thanks sbman, I'm still deciding on what I'll be installing as far as weight is concerned regarding bumpers, armor, shelving, gear, etc. so I'm not quite ready for springs but I may just be patient and order springs at the same time as the shocks.
No experiente with fox suíços otuer than on My Mountaine bike. I have only run the sports on my 80. They are definitely stiff unloaded but when loaded down and running rocks I love them. The feel safe and stable. As a reference, my DD is a 3/4 tone dodge. I enjoy a firm ride. To each his own.
