That's as good as it's going to get, the drawers in my 100 are the same way. If you're looking to throw a mattress on there to sleep it will bridge the gap and you will not notice the slight difference in height.
Just as @GTV said, in my last 80 I had a different drawer set up that sat similar to this. I would place a small gear bag in the recess and a mattress on top to sleep inside. Didn’t notice.
My plan was to fold the seats all the way forward and build a platform that extended level so I could store gear under it. This is still my plan just with a different drawer system.
As you can see from the photo the seats do not fold completely flat (not parallel with the floor), it’s lower in the rear than in the front. Since the drawers are flat you’re going to have some degree of misalignment there. It’s unavoidable.
Is anyone interested in a Miller Maxstar 161 S? Basically new in the case. With manual, ground cable & electrode cable. Dual voltage, comes with adapter cable/plug. I’ve only burned two rods with it and it works great. Just ordered a multi-process machine and don’t need this one anymore. New retail is close to $1500. Let’s start at $1000 obo
Bought used for my 3rd gen tacoma but I am going a different route with the truck. From previous seller: 45k miles Bushings replaced 22k miles ago Uniballs 16k miles ago Asking $450, also comes...
The Rough Country Skid Plate is for fourth-generation Toyota Tacoma’s, 2WD & 4WD - 2024 thru 2026. 11-Gauge Steel Construction. Fits Stock Tacoma Models: Direct Bolt-On for Stock Tacomas:...
CityRacerLLC LED headlights for FJ40/FJ55 for sale. Plug & play with original harness. 12V. Upper part lights up for low beam, upper & lower for high beam. $60.
Barry (505) 321-8316
1995 Toyota 4Runner. 22RE engine, 5 speed manual transmission, 4 wheel drive. starts, runs, drives- but probably needs new head gasket.
santafe.craigslist.org
Take your compression tester and a timing light. If it needs a head gasket, no problem. We replaced a 22re head gasket in a motel parking lot years ago. At the time, we had very little wrenching experience.
That's a nice find! I'd pour in a bottle of Bar's Head Gasket fix into the radiator, then drive it home! That stuff works amazingly well as a temp fix.
