Colorado 73 FJ40, 2F, $6000
For sale
1973 Toyota Land Cruiser FJ-40
Build date 11/72
Rebuilt 2F engine.
Very little rust, the usual along the back only. All bolts come out easily, not rusted up. Floors are solid, fenderwells, bed, solid.
Original 3 speed transmission with original transfer case. Rebuilt parking brake. All 5 stock wheels, disc brake compatible (from a '79)
Hardtop locks replaced so you can lock it up! Hardtop rebuilt, very solid gutter, all new rivets and bolts. Hard doors have new door seal gaskets.
High-back bucket seats (made by Recaro) from a Mustang GT with power lumbar and other adjustments - excellent!
Wiper diassembled, relubed, repainted, new blades.
Well maintained. Many parts replaced or rebuilt within the last several years - alternator, vac-advance distributor converted to electronic, clutch, rebuilt 2F engine, brakes, steering center arm, steering box coupler, water pump, replaced rear diff with a good front one. I keep the oils changed and everything greased properly, including complete repacks of front Birfields.
All factory gauges and dash controls work. Has halogen headlights.
Stock body with stock rear tire mount. Interior carpeted. 2 working heaters, one powerful aux heater under driver's seat. Rebuilt, working wipers and washers.
Crane XR700 electronic ignition in "non-USA" vacuum-advance distributor. Ported vacuum on Aisin carburetor.
Power brakes! Needs a new booster at the moment, old one is disconnected from engine vacuum. Smog pump is gone but I have most of the smog stuff around.
Has exhaust header and electric block heater.
Doestch-Tech DT8000 shocks. Downey Ultra Travel 3" lift leaf springs are fully slip-plated and it doesn't sag or lean. New extended poly bumpstops bolted in stock holes.
New CCOT all-brass 4-core radiator, never overheats.
Can be licensed as a collector vehicle in Colorado. Located in Longmont. Email me, jjatkinsNOSPAM@ix.NONSPAM.netcom.com for pics. $6000.
For sale
Build date 11/72
Rebuilt 2F engine.
