fog lights on a 45LV?
As far as I know, I have the lights in the factory location - it depends though which EPC diagram you look at. Some show the light mounting on the bumper itself, though other diagrams locate the fog lamp back on the chassis rail, like I have, and mount aux. marker lights on the bumper. It's a bit hard to tell on the left hand diagram below which lamps are 'clearance' and which lamps are fog. I'm thinking that the larger ones are the fog lamps and the smaller ones the clearance lamps, given the size of the marker lamps incorporated into the bib on early 40 models.
I looked at the options I had, and went with the mounting atop the bumper gusset as a well-protected location.
The brackets seem tailor made for those particular mounting positions, as the lower sweep of the bracket covers over the rear mounting bolt for the triangular bumper gusset. If I went and mounted them on the rearmost gusset bolt position, they would be up against the bib, so that's not the right spot.
The winch is from an HJ61, so I made a few small changes to get it to fit, and those changes are a little different than the factory mounting in terms of the width of the front angle iron mount, which I narrowed over the stock part. Otherwise the location is correct and the rear mounting of the winch sits at the correct height on the Toyota angled cast wedge blocks. The yoke is centered in the hole in the front cross-member and turns smoothly.
Landpimp hooked me up with Al a couple years back, been collecting dust on the shelf since then (hope it wasn't me looking for the part number with the pic :D).
I'm slow tonight... is the mount available Y or N?
Anyone know where I can get some replacement bulbs for these fog lamps? I have the fog lamps and mounts, but missing the bulbs. I am going to put them on my new FJ40, attached is a picture of my newly rebuilt 1976 FJ40...
the only hope may be
Daniel Stern Lighting Consultancy and Supply
I think he said he may be able to find/have some, but other than that, they dont exist.
The mounts should be available. I was able to order them about a month ago here in Guatemala though they have yet to arrive.
Anyone try ordering the mounts through the US parts system? Titus Will?
Are you wanting some? Apparently mine came in but I ordered a couple of things at the same time and some of the other parts did not come in yet so they're holding the brackets till all the order is there. I can try and order a few more sets if you like.
Well I picked up my brackets last week so they ARE still in the Toyota system world wide. The problem with the US system is that they either will not or cannot order older or special stuff.
Anyone have a fog light switch part number for a '67 FJ45LV so I can give it a go?
If you need these lights or brackets I can try for more if your willing to pay up front.
