Build Fly By Night
Well, if you’re not waiting on money, you’re waiting on shipping.
This, make a point to order from “in stock” source and the acknowledgement email says shipping Aug 28, wtf 🤬
That sounds like a great way to hybrid both approaches 👍🏼
Can’t say from firsthand knowledge of the bolt-on sliders, but from pics I’ve seen, the flanges for the bolts look to be 1/4” or 3/8”?
3 mounting legs for each slider? That’s where my mind keeps going.
As someone who's had to remove the welds and clean up frames that have had sliders directly welded to them, definitely go with bolt on.
I use 3/8 plate on the frame side and get 5/8 U-bolts bent up at a local spring shop. If you look at White Knuckle or some of the other popular brands, they all use a similar approach. Web photo below to illustrate.
On the 55 I posted above it's got 3 frame mounted and 1 that ties into a frame side body support on each side, it's an 80 frame though not a 55.
The other benefit of removable, is that if you do powder coat them they can be removed to be redone. I don't recommend powder on sliders though since if you actually use them they get scraped up by design, which allows water to get underneath the powder.
Thanks for this input Steve. I’d forgotten about the use of a u-bolt in this application. I thought everyone used an additional backside plate.
The Slee Slider Steps on my 100 use the custom U-bolt approach. I have banged those sliders numerous times and they have never moved.
Updates? Is this thing driving yet? 🐖 👈
Steve,
As soon as I found my solution for everything we talked about last week, I had to switch out of Landcruiser mode and go into river rafting mode. Heading up to the Rogue River in Oregon tomorrow. Had a couple projects to finish on the raft setup before leaving - shorten up the aluminum floorpan, and modify a 20mm ammo box (Rocket Box) into a ‘Captain’s Box’.
Steve,
Which section of the rogue you floating? Figure if your making a trip that far up doing 4 day float Starting at graves creek? Spent a lot of time on that river growing up.
Running the wild and scenic section, from Almeda(?) to Foster Bar. We’re taking 5 days.
Awesome yeah so starting just above graves creek. I think about 4 miles up river. Couple smaller rapids before you get to Rainee falls. Be safe it’s a beautiful trip thru all that country and the rogue is no joke. My pigs sitting about 40 minutes away from there waiting for transport to the port to come back home.
Back to Cruiser mode…
Getting kinda wishy-washy on which direction to go - was concerned about getting sliders built a couple weeks ago, now I’m concerned about getting the hood over the engine bay. Need to look in to getting the hood louvered, supposedly there’s a guy in Phoenix - waiting to hear back on that. If no, there’s lots of options for louvers in the form of little sheetmetal or aluminum panels.
The hood itself also needs work before it’s ready for paint. One of the PO’s had it fly open and fold the heck out of it. Looking forward to seeing what can be done with it.
So before that can get done, I want to get the upper fenders finished out. Upper driver side and both upper and lower passenger side were Swiss-cheesed with holes from drilling out spot welds way back when. Was dreading a little bit having to do it, but once got going wasn’t too bad.
Here’s one for the paint scheme conspiracy, ‘Two-Tone-gate’…
Started stripping off the paint (on both these uppers) and there was red on top of the primer, under the white.
