For Sale FJ80 1996 Front Axle Part out - Housing, Birfs, knuckles, ABS, hubs,etc
Deathvalleypaul
FJ80 Collector
Near Pasadena CA
SoCal
I am parting out a front axle from a 1994, non locker FJ80. Very good condition.
Birfields, $75 each (with shipping $88.90)
Shipping extra on the following items:
Housing $150
ABS Sensors $45 each
ABS Harnesses $45 per side
FRont Control Arms $60 pair - very bulky for shipping
Rear Lower and upper Control arms available
Axle Shafts $25 each side.
Third Member is high pinion $225 SOLD
Knuckles - $75 each side Passenger Side and Driver side available
Steeing Arms - 35 each side
Steering Box with Pitman Arm $175
Spindles
Hubs
Caliper set complete, shoes and all.
Rotors.
Tie Rod $45
Drag Link $25
Master Cylinder
See your private message on the coil springs.
Update, I am parting out a fresh axle from a 1994, non locker. see corrections in green
I'm going to be in L.A. at the end of January and I just bent my tie rod. Any chance you could hold on to the one you have until then? Thanks in advance. Jason
Not trying to cost Paul a sale ........
But if you bent your tie-rod, then you might want to consider the HD tie rod and drag link from Marlin Crawler. Pretty common issue for 80s that get wheeled.
But if you want/need a stock replacement ....... Paul is a great guy to deal with!!!!!
Georg @ Valley Hybrids & Cruiser Brothers
Thanks Georg,
I used the Heavy Duty one for a while, then wound up bending the tie rod end itself (the large one and it was a Toyota factory). I am back to using the factory tie-rod and factory tie-rod end.
Yes, it is non-locker housing, straight and ready to mount. $150
