mattressking
10 digits to freedom
Don't make all this harder than it needs to be. OEM toyota filters do the trick and are around $5 new. You can also grab the big 15600-41010 filters from @HemiAlex if you want to be fancy.
If your motor is resealed top to bottom, feel free to use 15w50 Mobil1 Syn like @HemiAlex . Synthetic is great, just leaks if motor has odl seals. Otherwise Rotella or similar diesel oil is sufficient. Oil WEIGHT is dependent on your climate, so don't judge based on user input, judge based on your ambient temperatures. Add ZDDP additive if the oil you use doesn't have a lot of zinc.
If you really want to be anal, get an oil analysis with mileage recommendation from Blackstone or similar company.
For example I run OEM filter, rotella T4, 15w40. My ambient temps average 60s-70s most of the year but if I'm traveling to desert often I bump to 20w50 for the added viscosity.
