My wife has recently been DDing my FJ62 and in the pass couple weeks its started to develop a hard start issues. At first it wasn't happening all the time, but has progressively gotten more and more consistent. Once it does fire up it runs fine, but it's gone from it's typical wuh, wuh, wuh, vroom to wuh, wuh, wuh, wuh, wuh, nothing, try again, wuh, wuh, wuh, wuh, wuh, wuh, vruh vruh vroom. plus or minus a couple of wuhs here and there.
Just some history, FJ62 is sitting at 226k. I got it just before 215k, had it on jack stands for three months and when through every mechanically that I didn't receive receipts for and fix and replace a whole lot then. Plugs and wires were done just before I got it. I deleted the EGR and smog equipment, replaced the fuel filter and pick up screen. All the vacuum lines have been replace with silicon lines, so I'm pretty confident there are no vacuum leaks. I'm pretty sure the PO had the injectors cleaned, I have to look back at receipts. I do run techron through the tank from time to time to help keep them clean. Pulled the cold start infect to clean that and surprisingly, it was almost spotless. Also, recently cleaned the MAF again.
Tried to pulled the IAC valve, but one of the screws started to strip and I figure I'd have a better opportunity to get that off when I pull the intake. I did pull the hose and hit it with some cleaner the best I could. Also, seafoam'd the top end, barely any smoke, but I this previously when I first it.
My first thought was the Fuel pressure regulator, so I replaced the original Denso (no longer available as far as I can tell) with a SMP PR88, no luck. I've got a Fuel pressure dampener waiting to go in. I'm planning on pulling the intake to get to the dampener a little easier and to finally remove the air injector rail. Just have to order new intake gaskets. However, I'm not really holding my breath on the dampener fixing the hard start. So, I figure I'd just go ahead and order a fuel pump.
Looking at Rock Auto I don't see many brands I trust, besides carter. I don't know much about Carter electric fuel pumps, just use their mechanical ones on SBC's, but their electrical ones have different connectors compared to the post style terminals of the OEM ones.
So any suggestions on brands you've used and have had luck with is appreciated.
