Where can I purchase the Cold Start injector time switch? for 1988 model. Thank you.I can help here :
YES drain your Radatior say only a gallon or so , is needed to remove :
then :
you have all this to consider what all you needs and wants are in the world of the 3FE thermosts housing :
FJ62 3FE / 3F-E Repair Refresh Restore KIT OEM Genuine NipponDensso JAPAN , Fuel Pressure Temperature Switch Sensor , SENDER WATER TEMPERATURE Gauge Fits 87 -90 . GREY TIP 1 wire comes with the OEM Connector Plug , Seal and Extra Terminals - Vint
SWITCH , Fuel Pressure Temperature Sensor Genuine NipponDenso OEM JAPAN Parts Comes with Repair Refresh Restore Connector Kit and Extra Terminals ...vintageteqparts.com
3FE PLUG and PLAY REPAIR KIT OEM Toyota BVSV VSV Valve, Bimetal Vacuum Switching, NO.2 ( FOR E.F.I ) 25820- Fits 88 -90 FJ62 USA & Canada Spec. sensor sender 3FE Vacuum HOSE TOO ! FJ80 also - VintageTEqParts.com
NOS OEM Toyota Comes w/ a nice long section of OEM toyota Factory Vacuum hose also ! Valve, Bi-metal Vacuum...vintageteqparts.com
Genuine YAZAKI OEM TOYOTA Water / Coolant Temperature Sending Unit Sensor w/ Genuine YAMAHA Repair Connector KIT & Special Positive-Grip Detent-Ball Locking Terminal 2/76 - 1992 BJ42 FJ40 FJ55 FJ60 FJ70 FJ80 FJ62 HJ60 2F / 3F Carb 3B 2H 1HD-T 22R
- Genuine YAZAKI OEM Toyota MADE IN JAPAN -Spec. Parts - Water / Coolant Temperature Sending Unit Sensor ( For...vintageteqparts.com
OEM GENUINE NipponDenso / DENSO Japan Spec. Parts 3-FE PLUG and PLAY Repair KIT Sensor, Sender Water Temperature ( For E.F.I.) Fits 88 - 92 FJ62 FJ80 3FE USA & Canada Spec. Also Fits : NON-USA 1HZ , 1KZT , 2LT , 2UZ , 22RE & 1PZ Engines
- OEM GENUINE NipponDenso / DENSO Japan spec. parts - Includes the Green & Yellow Service Spec. Connector Kit w/ rubber...vintageteqparts.com
3FE PLUG and PLAY REPAIR KIT Cold Start Injector Thermal Time for EFI Timer Switch SENSOR Sender for Land Cruiser FJ62 FJ80 Pick-up 4Runner Fits 88 -90 FJ62 USA & Canada Spec. sensor sender 91-92 FJ80 89462-20040 - VintageTEqParts.com
NOTE: This DOES NOT Come with the Wires Attached to the connector .... Cold Start Injector Timer Switch SENSOR Sender for...vintageteqparts.com
