FJ60 Brake Booster options
I hear ya. I just don't like that it's got a hard and sort of non responsive feel at the top of the pedal. I'd like it to immediately start to sink and start to grab.
Maybe someone smarter than me can chime in, but I think adding a master cylinder with a larger diameter piston may help firm things up faster. The T100 MC has a larger piston from what I understand. Also, the 4Runner calipers have two large pistons as opposed to one large and one small in the OEM caliper.
I don’t have experience with it myself but I have read that adding stainless lines in place of the old rubber lines will also help firm things up.
I am putting a double diaphragm in my FJ40, not sure if it is for a an FJ80. The master cylinder is for an FJ80.
I ordered the city racer booster today. Going to try that since there is positive feedback on this one. It's a double diaphragm. No idea if the 94 4 runner non abs booster that I have now is single or double diaphragm. I don't think a larger master is going to be great without larger calipers and discs.
I am installing 13.3" rotors and Toyota V8 calipers on the front and the rear and FJ40 disc FJ40 calipers so I will have more hydraulic power for the 4 disc set up.
Where can I get an FJ60 radiator? I have search all around and could only find a cheap one on Amazon. Are there other radiators that are interchangeable or is it specific to the FJ60? I’ve checked all the auto stores and they don’t have any. Thanks for your time.
Read the title of this thread. It is a brake booster option thread. Find an old radiator thread using the search button top right and post your comment/question. Or, start a new thread.
UPDATE: I just finished up swapping the 94 four runner booster for the City Racer Booster. That fixed my issues. No more stiff pedal at the top. The City Racer booster goes in with the check valve at around the (EDIT: 7 oclock position) so no need to use the metal vacuum line that goes under the master cylinder. I didn't use the extension block that comes with it or the cone shaped plastic that goes over the pedal rod. The cone isn't going to fit the hole in the firewall. I did reuse my paper gasket, heat shield, and the clevis fork that connects to the pedal. Now let's hope Advanced Auto doesn't give me crap when I return the other booster that I couldn't get to work.
UPDATE: I just finished up swapping the 94 four runner booster for the City Racer Booster. That fixed my issues. No more stiff pedal at the top. The City Racer booster goes in with the check valve at around the 5 oclock position so no need to use the metal vacuum line that goes under the master cylinder. I didn't use the extension block that comes with it or the cone shaped plastic that goes over the pedal rod. The cone isn't going to fit the hole in the firewall. I did reuse my paper gasket, heat shield, and the clevis fork that connects to the pedal. Now let's hope Advanced Auto doesn't give me crap when I return the other booster that I couldn't get to work.
Is this the dual diaphragm booster that you got? I've been curious about those since I use the larger T100 master cylinder but still have the factory booster in my 62.
Yes, dual diaphragm.
We’ve installed dozens of the City Racer boosters in the last couple years and they have all been good.
The dual diaphragm booster from an earlier 3rd gen 4runner works too. and usually comes with the "t100" master cylinder attached to it. I picked up my last one at the pull yard for like $20 for the whole thing.
What did you guys end up going with and how did it turn out?
I've been looking at FZJ80 booster or a Wilwood aftermarket.
I know OEM replacement is the way to go.
Some of you guys went with larger discs and calipers, I really don't want to buy 17" rims either.
Unless I can find some 6-lug rock warriors for cheap I'd gladly throw those on.
I went with the double diaphragm and the FJ80 Master cylinder and got the package from Redline in CO for my FJ40 and I up graded to the big brake kit. I also used front discs and calipers on the rear when I converted to disc.
I did go to 17" rims on my build and bought them from TOYOTA - https://www.stealthcustomseries.com/collections/toyota because they had 6 bolt pattern that is compatible with hubs. I wanted the right offset and they set me up. They provide rims for Toyota and Jeep applications. 2 of there models work on axles with hubs.
4 runner booster from a 1996 should drop right in. I used a master cylinder from a T100 of the same year model. Replace all the soft lines with stainless lines if you want it a bit stiffer. I’m also using 4Runner calipers up front. I have great stopping power, however the pedal isn’t hard. It’s not spongy either. It’s kinda just right. The only way I can lock up the brakes is if I’m in neutral. It’s scary when that happens because the weight distribution is off. Having the transmission engaged helps the truck remain balanced as you come to a stop. You can stop quicker with it in neutral, but you’ll be fishtailing a good bit and shyiting your pants.
I'm late to the party on this but what year are the 4Runner calipers? From the 1996 era as well?
