I will not have the benefit, nor do I see any need, to cycle the suspension for accurate compressed and extended shock lengths.
I've searched, have spent time comparing OE specs to aftermarket options, and there's so many differences, thought I'd ask for y'alls input or experience.
Keep in mind, I don't have access to a Pig, at this time, nor did I have any way to estimate what "stock height" was, when I tried.
First.
Will a 2.5" shock even fit in the front OE tower?
Have no need to modify the tower for larger, but if larger is verified to fit, always a better option.
Second.
The '69-'74 Chassis and Body FSM specs:
**Front**
Compressed 13.31" (338mm)
Extended 22.36" (568mm)
Travel 9.05" (230mm)
Dampening at 1ft/sec (.3 m/sec)
Comp: 79lbs (36kg)
Rebound: 242lbs (110kg)
Front has a lower eye and upper pin bolt. The pin bolt length needs to be as short as possible to minimize cutting a hole in the inner fender to accommodate.
**Rear**
Comp: 79lbs (36kg)
Rear is eye to eye.
I checked all model years and the part number for front/rear were the same, so the earlier FSM should, being operative, have the correct info.
In comparison, these lengths are around 2" longer than what Monroe lists as OE replacements and close to what OMEs chart shows they sent with the 55 specific kits, how ever long ago it was they produced.
According to the leaf manufacturer, the +2" requested, based on no additional weights, should net +2" to OE height....but I realize it's not a precise science.
I had figured I could add 2" to the OE extended lengths, work backwards to ensure the compressed was around an 1" longer than OE, but when discussing with shock producer, the first question asked was if the OE lengths I had provided (those above) had been adjusted for lift, already, because they were longer than any other product offering, so reason for asking for assistance.
First.
Second.
**Front**
Comp: 79lbs (36kg)
**Rear**
Comp: 79lbs (36kg)
Rear is eye to eye.
