It's just an old school term for positive feed from the battery.What is "Radio B+"?
So the original radio wasn't switched? It was always on?It's just an old school term for positive feed from the battery.
No, it was a positive feed line from the switched or accessory portion of the fuse box. I think earlier versions were on a shared circuit with the wipers, later versions had their own fuse. But if you're putting in a modern stereo that also needs an 'always hot' feed for the radio memory then there's likely a extra unused tab on the back of your fuse panel to plug right into. It'd be on the cig lighter/interior lights fuse.So the original radio wasn't switched? It was always on?
ok, so "Radio B+" is not a feed from the battery, but is actually an I/O on the same fuse that is connected to the Wiper power which is switched with the ignition.No, it was a positive feed line from the switched or accessory portion of the fuse box. I think earlier versions were on a shared circuit with the wipers, later versions had their own fuse. But if you're putting in a modern stereo that also needs an 'always hot' feed for the radio memory then there's likely a extra unused tab on the back of your fuse panel to plug right into. It'd be on the cig lighter/interior lights fuse.
Can you tell me what #41 "Key Switch" is for? And also, what is terminal #64 used for? thanks
That would be the ignition switch. If you look at the spreadsheet in this LINK #64 is for the horn.Can you tell me what #41 "Key Switch" is for? And also, what is terminal #64 used for? thanks
