FJ40 to HJ40 Build
how did this go? hope everything went off without a hitch!
So I spent this weekend swapping in a newer engine. Got it in and running now. Just have to wire up the EDIC and change the throttle setup, also change my new rocker arm and rockers. So here are some pics of the gasket matching I did to the exhaust side.
So I got my second engine in. Been running it up and down all week. Tomorrow I will flush the oil and put my good rockers and shaft in. So what I did to make the EDIC work was swap the motor with a 12V one and 12 Regulator, hooked up the three wires and it was all good. Well almost had to adjust the motor some but it was a learning experience.
So I finally got off my butt this weekend and did something. So I swapped my master cylinder to an 80 series aluminum one, this helps in many ways. Primary cause my old one was failing, second the length of protrusion goes from 8 3/4 to 6 1/4, plus a bigger bore 1". The second thing is my block heater plug.
Update? did you ever get this roadworthy?
Ok, I hadn't realized that was the same rig.
Its been sitting as a paper weight as of late, but seen how you asked I will start posting more pics as I do stuff.
Got that STOUT track bar in yet man?? :D
I cant believe you aren't climbing the walls with anticipation of wheeling that thing.... so many new goodies to try.:popcorn:
Go to the first post in the thread, click "edit", then click "go advanced" - this will let you edit the title and the original post.
-Steve
That never works for me. I do it, and it SEEMS to work, but when you go back to the forum index and look it doesn't change.
