- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
@ToyotaMatt you got a part number for the nut that would go on the studs for the thermostat housing?
Nope, it’s yours in my book.
@letterman52
I cant take credit for the idea. Another mud member & vendor @ToyotaMatt mentioned using a stud in place of a bolt. I just stumbled across a proper length stud.
They were out.
Did the FJParts gasket end up being 3mm thick?
Thanks for the great write up. I just replaced my thermostat but it hasn’t change the status. What temps are you seeing at the housing? I can’t tell if my reader/sender is bad or if my coolant is too hot. 205 at the thermostat housing, about the same at the top of the radiator then 135 exiting the radiator. Normal? Or too hot?Since it has been nine years since a thread has been created discussing the installation of a thermostat on a 2F engine, and since I spent about 30 minutes yesterday trying to figure out how to do the installation correctly with the odd gaskets that are included in different rebuild kits, I thought I would quickly show the steps that one would take to properly (hopefully) install the thermostat. (Also the old thread has lost its picture links)
EDIT 8/12/19: Cool Cruisers and SOR have gaskets (upper, lower - thick and thin) readily available. Search on their sites for "thermostat gasket". Not sure (it's been a while) but there may be OEM parts available as well. Search on your favorite Toyota parts website).
1. On a cool engine, locate the thermostat. It is on the front on the straight 6 engine (F thru 3FE). In the photos below it is circled in yellow.
View attachment 1479621 View attachment 1479622
Place a bucket or pan underneath and loosen the hose clamps. Allow the coolant to drain into the bucket.
2. Remove the top half of the thermostat housing by removing the two bolts. Remove them slowly and carefully as these have a high tendency to break within the aluminum housing. They are fairly thin and long, and bind up in the aluminum due to the increased exposure to water.
3. Remove the old thermostat from the housing if you are going to replace it with a new one. If you are not then you should test the thermostat to make sure it still works by placing it in a pot of water and monitoring the temperature until it reaches the proper expansion temperature. At that time the thermostat should expand.
4. Remove the old gasket. Clean the lower and upper mating surfaces of any residue from the old gasket. Use a razor blade to scrape for material from the face of the thermostat housing, and then use a cleaning agent like general spirits, brake cleaner, or other non-residue creating cleaner to remove the oil from the surface.
5. Insert the thermostat with the visible spring facing down and the domed part up. It should fit into the lip in the lower housing. Install the thermostat so the "jiggle valve", as the FSM describes it, is located at the 11 to 1 o'clock position in the housing. It allows a little circulation until the thermostat opens. (NOTE: the thermostat pictured below does NOT have a jiggle valve).
This is the bottom:
This is the top:
I was thinking about replacing my thermostat on a 1978 FJ40 because it is so old but after reading this thread, I am hesitant to tear into if for fear of breaking bolts and gasket issues. Can I use the four bolt system available for 1980+ models without any issues? Does it make sense to install the 4 bolt kit rather than trying to deal with the current 2 bolt system? Did anyone ever figure out what the 12 o'clock reference was to? front of engine to back or back to front?
Hello.
Hope someone can help me!!!
I have a 81 fj43 2f. It started overheating and driving me Crazy.
I replaced the following new.
Cruiser Corps aluminum radiator
OEM 190 t stat
New radiator hoses
Oem water pump
Sending unit
Burped level and incline using burp funnel, drove repeated several times,, removed temp sending unit once cool and topped off, burped again. Flushed with water and ran in between flushes 8 times. Clear full water flowed out of block drain.
Upper and lower gaskets are sitting correctly on the thermostat.
Still, It quickly gets max hot but not instant, as per the stock OEM gauge it also smells like it's getting really hot. Feels like it's getting super hot. The top of the radiator is super hot and the top radio to hose is really hard to squeeze. The bottom of the radiator is pretty cool and not as hard as the top hose at all.
Since this, I next got a 180 aftermarket thermostat. I removed OEM 190 thermostat placed it and the new 180 t stat in boiling water, both opened. Installed new 180 t stat after flushing again several times spraying hose into front of block, into sending unit, sprayed into drain, and flushed radiator, drained and flowed out great everywhere.
Will fill again and start to see what happens. Hope for the best. Just don't get it. I used 50 /50 red antifreeze with water wetter This time I'm using 70 /30 green with water wetter. It is driven fine and not overheated with the 50/50, red etc. For the past 2 years. This problem just came up.
Ordered laser thermometer. Will check different locations and post that soon as I can. I will also ground the wire to the sending unit to verify a grounds and goes to full hot.
Thank you all so much for your help and patience. I did read through every single post on this forum that I could find including this one more than once. I feel like I'm chasing a ghost
Thank you. The vehicle is desmogged. Don't think it ever came with smogged anything as it came from South America. Advanced vacuum going through the distributor is a brand new piece and I didn't touch anything with the distributor after I changed it out a year ago with all new parts and it's been running beautiful ever since. So I don't think it's anything with the timing because right before this started it overheating for the last year I had no issues and didn't change anything.That is pretty thorough!
I only have one more thing to check - your distributor advance mechanism, and the ignition timing in general. Retarded timing will produce extra heat. I have seen badly-retarded engines that would heat headers to cherry red, and still run semi-ok. When I first got my own (12/79, 1980 model) 40, it was running hot on the highway until I found that the vacuum advance mechanism had rusted and was inoperable. Replacing the distributor with a rebuilt unit fixed it. I was also able to advance my base timing a bit since I am de-smogged.
Thoughts, I'm at a loss
Hey John, yes I Just got my laser thermometer. I will check the temps in these locations and post what I find once I get it done. Going to fill it with straight distilled water just to flush out the hose tap water and check everything before I drain again and refill with 70 /30 green fluids again for the 30th time LOL. The way I do not have a heater installed so there's no heater lines to mess with in case someone ask.You’ve done a good job of trying to fix your problem. I would suggest checking your temps with an infrared temp gun. I know you said you replaced your Sender…but you may be chasing a ghost. Infrared to be certain.
