FJ40 stalling when stopped
F.E Warren AFB, Wyoming
Over the last month or so my 40 has stalled three times when stopped at a stoplight. Fortunately, i am always able to get it started after it sits for about 5 minutes. Today it stalled while in a fast food drive through. Not fun! After i got it moved i could not get it started. 20 min later it fired up.
There is fuel in the carb site gauge. Coincidently, i have been having brake booster issues also. (Front discs are locking up-I think I need to shorten the booster)
Where should I start troubleshooting?
Idle solenoid? Float? Thanks for any input!
...via IH8MUD app
Knowing that there is fuel showing in the sightglass eliminates fuell supply, so it's not the pump, filter, needle & seat, float...
When problem occurs, try diconnecting/connecting electrical connector to ICS w/ KOEO. Does the ICS click?
It would be great if it could be narrowed to fuel or spark. Easy test for spark is carry a spare spark plug and put it in the end of one of the wires, lay it on metal where you can see it, then crank the engine. Got spark?
Alternatively, carry "fuel in a spraycan" i.e. Gumout spray carb cleaner. When it dies, remove aircleaner wingnut and squirt some carb spray in around the air cleaner stud. Crank engine. If it fires, then engine is not getting idle fuel.
its probably a vacuum leak, could be related to the booster issue. mine did the same thing before i tossed the weber and had the manifolds machined flat, new gasket, etc...you are probably flooding it when you are trying to restart to get it going again, thus you have to wait for the fuel to evaporate.
As a practical matter to avoid stalling while you are figuring all this out, you can bump up the idle speed so it doesn't stall. The idle screw is in the cast iron carb base facing the fire wall. It is hidden by the linkage and hard to see. It is not one of the screws that is part of the linkage.
I think the Kid has the answer---mine does the same thing--does it occasionally backfire through the carb?(may be an intake valve stuck).
----A note on the idle up--(pushing a little too far might cause the engine to "diesel" when shutting down--just be ready--I have to use my hand throttle for this)
Mine was dying at stop signs or light. It turned out to be the brake booster. Vacuum leak internally I guess. No noticeable problems with the brakes but engine would stall when you got on the brakes hard. Changed the booster and solved my problem. Hope you get it fixed. It's frustrating for sure!
...via IH8MUD app
Update:
I have narrowed this issue down to spark. The last time it died I wasn't at a stoplight, I was driving. I put a test plug in, cranked it over, and had no spark. I took the coil out and took it in to get tested. Tested good. I threw it back in, made sure all connections/grounds were good and tried to fire it up. Nothing. Waited for about 20 minutes for the wife to come pull me home and decided to give it another shot. Fired right up. As I was backing up, it died again.
Equipment: Denso distributor with electronic ignition/flamethrower II coil about 1.5 year old. Could the ignition be going out already? I just don't want to throw expensive parts at it. Any recommendations on the next troubleshooting step? ^^Thanks for all of the previous help!
...via IH8MUD app
Fusible link to the coil overheating?/
You know it's not getting spark. And you know the coil (which is a simple device) tests good. That leaves the pertronix, which is a very tiny electronics package inside the hot, vibrating distributor. They are know to fail to such an extent that some airheads buy 2 for their bus. One in the dissy and spare in the glovebox.
Just sayin...
Had the same problem on two occasions, same symptoms but different causes. Once it was the (-) neg wire from coil to the dist. The wire was broken inside the insulation. I replaced the wire, problem fixed.
The other time it was a worn out ignition switch.
'74 FJ40
