FJ40 Fuel tank hose
Here is a couple of pics of a disassembled OEM fuel fitting.
The first pic shows how the hose is crimped on. Cut this metal crimp with a Dremel tool and you will then have the two pieces shown.
As Stuchizik stated, take these to a hose shop and have them use the pieces to make a new one. You might be able to get a small hose clamp on there to hold it.
This does require that you have one of these fittings. If there is a machinist out there willing to make up some of these I have the set shown I could loan out. It is NOT for sale. :D
I do not think that fitting is 14mm x 2.0mm....
Thanks for the pics. That really helps. I assume the other piece is what's known as the olive? Is that a sleeve on the olive or a machined shoulder? Does it need an o-ring or seal between the olive and the nut?
Same issue with the early 55's. I fixed mine by using the fuel line nuts for the carb and a ferule anlong with a small section of stock fuel line. Worked just fine. The nuts and ferules were still available from Toyota a couple years ago.
Trollhole is correct, Spector sells the ferrule and nut, the problem I had was that the Hard fuel line was about 5/16" O.D. and the diameter of the fuel tank output I.D. is about 3/16" so the hard fuel line will not fit unless you drill out the Bung on the fuel tank.
Went this route...Jusssttt Kidding :doh:
Bringing this up from the dead, in case anyone searches and finds this thread, as I did. I have a 1971 FJ40, and could not find any of the discontinued hose assemblies. My fuel hose looked to be original, so congrats Toyota on 50 years between hose replacement! Anyhoo, Cool Cruisers makes just the ticket here, a perfect brass threaded adapter, and it arrive in a matter of a couple days from Texas to NJ: Gas Tank to Fuel Line Connector 1968-9/72 FJ40 - Aft Mrkt - https://www.coolcruisers.com/gastatofulic.html
The adapter, some 1/4" fuel hose (about 3 ft.), a couple clamps and you're back in business in no time.
