Build Fj40 Daily and Wheeler build
Now that you have had some time to run your rig, how are you liking the Lizard skin and raptor liner? Are they holding up well? Would you recommend that combo?
I'm liking both a lot. The uncoated lizard skin on the bottom has held up great so far, and it works very well for sound and heat, and the raptor liner just makes life easier. No need to worry about the paint, I can toss tools in no problem, people climbing in and out don't have to worry about scratching stuff. It's 100% worth doing IMO.
Did you use both the ceramic and the sound insulation? How is it holding up to heat from the exhaust? Did you sound control the firewall?
Yep, entire underside and firewall in both sound and ceramic. It has been holding up very well as far as I can tell.
The removable firewall insulation was a game changer and worth the time. The lizard skin seems really fragile to me. It does help with heat. The raptor I'm a little torn about. I think linex or rhino is tougher and I might have had them do it. As you see in my thread prep is important. There is also the lizard skin sound control which I did not use. I think it's unlikely sound control would make any difference. Fj40s emit low frequency noises, and for that you need really specific and thick sound insulation.
What has been happening to your lizard skin?
Nothing. But if I'm pulling out the tcase for repair and hit the lizard skin with the tcase it will scrape off the lizard skin. It's just kind of fragile and brittle it seems unless i mixed it wrong or something. I don't have it applied anywhere where durability is really needed much so it's fine for me.
I talked to the local Linex guy and he said that I would have to sandblast the Aqualu tub to get the adhesion. He also noted that if it was near the exhaust/ muffler, it may still peel off due to the heat.
Makes sense. You could make some heat shields during mock up first.
@White Stripe What did you do for threads in the circles below? Did you tap the aluminum, or did you put in rivet nuts?
I tapped the aluminum. Only heavy items like seat brackets or roll cage mounts got nuts on the back.
Finally got the 40 out of storage. I've moved 4 times in 2 years and had 2 surgeries. So I let the 40 sit until things got settled. Has a rear axle seal leaking. So I'm going to avoid driving it until that's fixed. I also can't get the rear locker to engage. I bought a challenger lift for one of my garages, so that will make stuff easier. In my travels I picked up some parts to give the 40 some more pep later on. While in storage the clutch master leaked and ate up some of the firewall paint. Ill have to fix that paint eventually.
Finally got the 40 out of storage. I've moved 4 times in 2 years and had 2 surgeries. So I let the 40 sit until things got settled. Has a rear axle seal leaking. So I'm going to avoid driving it until that's fixed. I also can't get the rear locker to engage. I bought a challenger lift for one of my garages, so that will make stuff easier. In my travels I picked up some parts to give the 40 some more pep later on. While in storage the clutch master leaked and ate up some of the firewall paint. Ill have to fix that paint eventually.View attachment 3537517
This is a bad ass 40. Hope you can get it back on the road to enjoy it soon!
Lift is installed in my garage. It's really awesome to take your time on repairs at my leisure. I have a fuel leak where the lines go through the floor. I need a new oval grommet for the floor. Since the aqualu floor is so thick, I'll have to make it. I bought a sheet of 1/2" thick rubber.
Lift is installed in my garage. It's really awesome to take your time on repairs at my leisure. I have a fuel leak where the lines go through the floor. I need a new oval grommet for the floor. Since the aqualu floor is so thick, I'll have to make it. I bought a sheet of 1/2" thick rubber.View attachment 3661255
You can also use double ended barbed / AN fittings theu the floor, to avoid chaffing and damage to fuel line.
Replaced the fuel lines. Frame has gotten some speckled rust from storage. So I'm taking some spots back down to metal and treating with ospho. Removed the battery for better access. This blue top has been a great battery. I keep the warranty slip taped to the side in a zip lock. Makes it easier to keep track of it.
88863072
Got the frame cleaned up. I'm no longer in a area that dumps mag chloride and salt brine all over the roads. So I should be good for a while. I touched up my battery tray with raptor in a aerosol can. Works great but the can doesn't last long. One of my beadlocks is leaking so I'm going to fix that. I also sent Alcan an email about getting some new front leaf springs with a different design.
