I'm truly not worried about getting a rebulit carb back.
Do what you have to, in order to get one good carb for your wagon.
the venturi bowls are seperately machined and then fit into the venturi bore and peened into place( a punch used to drive a score mark into the casting whose edge overlaps the lip of the bowl in order to hold it in place. I don't think the bowl have a correct clocking to them, just need to flush out in their bores and then be staked into place...not sure how to keep all the blasting media from entering that diaphram; maybe a rubber vacuum line plug over the nipple and some tape or maybe even some rtv around the plunger arm. can peel the rtv off after blasting...???
Gorilla tape is what my blaster uses, not sure exactly how you'd seal it off since you want all the metal bright for plating
Tucker
on the later carbs, the diaphram that is rebuildable is the vacuum secondary lift diaphram; I think the one you have in question is the throttle positioner diaphram- NOT certain> where on the carb was it and what linkage does it pull? The idea of the rtv would be to keep media from getting into the diaphram from around the plunger rod. dont know how well it would work- just an idea. maybe a later nicer diaphram assembly could be adapted to work the same but look better without need for plating...
not flush out the bores; flush IN their bores- seated fully...before peening or staking into place
I want to see the after photos.
Chris,
Are you planning on painting the main body of the carb. or leave it natural.
No, I'd prolly leave it natural, also. The only reason I asked is seeing that one painted was nice and the alum. ? body will turn dark again pretty quick.
I should of painted my transfer case and pto cases as they're turning dark and I haven't used them yet.![]()
I have no experience in clear coating anything. Personally if I were to put something on it, it would have a pigment in it. Light grey, etc.
That axle housing is clean. I would think not good for Alum. That's in Ohio? Shame he's not closer, I'd like to dunk a body and see how it turns out.
