Build Finally Tan 87 touched slightly.
Love seeing this! You’re making it look easy. Very intrigued about 80 coils and axles on a 60 frame.
Keep it coming!
Ed
Do it! The front is *relatively easy. The rear is more complicated.
*easier & less time consuming than an engine swap.
It seems intuitively obvious that the front would be harder to swap than the rear, what with steering alignment and the swaybar under the engine.
What makes the rear more difficult than the front axle swap?
The 80 frame is several inches wider at the rear axle than the 60, so the coil buckets on the axle have to be cut off and moved inboard. The 60's rear mounted gas tank interferes with harvesting the entire upper coil bucket/ link bracketry arrangement, so it has to be dissected and extensively carved up to fit. And fit is a relative term, because it doesn't fit perfectly. An 80 rear axle on leaf springs is the quick and easy way to go.
The front seems harder at first glance, but once you have the axle centered in the wheel opening, it is just a matter of connecting the dots with the 80 parts and relocating the steering box.
*the fine print is that this only applies to either FJ62s or FJ60s that are no longer using the '85+ factory transmission crossmember mounts as this is exactly where the rear radius arm mounts land.
Engine is mounted and I found a home for the 12ht
When I was getting ready to take the tan truck apart, I just couldn’t do it. It is just to nice. Starting a new thread in the 45 section. The chasis and 2uz are going under the 45.
What!? I need more 60 inspiration. Change your mind.
Love the 45. Will enjoy watching either way.
All, beautiful vehicles, the 40, the 60 and that 45 is absolutely gorgeous, that is one of the coolest colors! All are amazing -Matt
Well I am going ahead with the 80 axels under the 60. Rear is done progressing good on the front
