Finally a 100 owner....
The rear went up exactly 2.5" and the front 2" and I got them about the same. just 1/16" off.
The rear
Also ripped off the running boards, what goes up front to keep s*** off the underside since mud flaps are gone.
Did they park on something that was on fire??? Sliders or factory mud flaps. Other wise you get little rock chips. Although the toyota "rhinoliner" on the pinch weld area has held up on mine. Not too many chips.
the flash shows things that the eye does not, So you see the under coating and road grime.
That what you mean?
That what you mean?
Yea, the flash makes it look burnt :confused: . Thanks, I should take pictures of the underside of mine with a flash and see where all the crap is and clean it. Could only imagine how much junk is up there :rolleyes:
Final readings, anyone offer larger cams to clean up the alignment numbers?
I also removed the rear sway bar and used white grease on the bushings and everything else I touched.
I also removed the RF inner fender liner to gain access to the antenna. took it apart to remove the broken mast.
Great job, Shane! I'm afraid to ask what this would cost a fellow mudder, just in parts. Was that OEM carpet too?
This restoration must be the first sign of the 100 series aging.
Leather and install of leather as I just don't like doing it. $1,100
Heated inserts $150
Steering wheel and shifter $480
Carpet $780 I can buy it and ship on your dime. Need your full VIN to order.
Springs and shocks $550
LED bulbs $120.00
Infinity speakers $140 (4)
Cleaning supplies $50
Tires 315/70 x 16 BFG's $240 x4
Yes, the factory front mud flaps allready mentioned. I don't know the part number but CDan can get them for you - if my memory is true they are around $80 for the pair.
What MidTex said.
Ordered a few hours ago $36 each.
Also not happy with the ride, so I need to think it over. It is pretty harsh and you know it when you hit a bump, not what I was looking for. Ill put some miles on it and see what happens.
Also not happy with the rake, so I am going to index the torsion bars today.
I got the Husky liners for the front and middle row and very happy with them.
