Fender drama
America
Hi Guys! I'm Rick; new here and seek guidance. I came into a 1974 FJ40 project. It came with fenders, that I assumed would fit. However, I guided them into place and it seems way off. Am I doing it wrong ? should these fit, or do I have fenders that dont match....Here's a couple pics from the box etc. Thanks for any wisdom...
Welcome.
They are not a factory piece; they are aftermarket.
They are 'close' to the same, meaning, they have the same general shape.
Mounting holes will most likely be, not so 'close' to factory.
You will need to 'massage' them to fit.
Taiwanese fenders are known to require some modifications to fit properly.
Love it. The whole vehicle is a rat rod learning process. Can you clarify if the body is Standard bolt, and the engine is metric? I get different opinions, combined with whatever the previous owner opted to use...
For your viewing pleasure. Do you guys use Ospho for rust ? metal pan/catch for catching the excess that drips off ?
The shock is on the wrong side of the tower, this will cause major interference with the fender.
Also weird shackle reversal. PO may have moved axle forward.
Here’s some of my methods for dealing with rust. They may or may not work for ya but here they are.
I used Ospho at work and home for years. (Stock item and free). My complaint with Ospho was when ya left it on overnight like the directions say, the powdery residue left needs to be wire brushed all over again. Now when I use Ospho for rust treatment I wire brush the best I can, brush on the Ospho and brush it in vigorously and liberally, let it sit 20-40 minutes till it turns black, rinse well with water and a scrub brush to get all the residue off. Blow it dry with the air hose, wipe down with lacquer thinner to evaporate any moisture left and then I prime it.
Another product I like is Corroseal rust converter. I was using it today in fact. I’m replacing the rear springs so with them removed it was a good time to treat the perches, spring mounts, shackles and shackle mounts as they were getting pretty rusty. Also the rear frame corners where that diagonal brace makes it hard to get to.
I pressure washed all of it good the day before and today with it good and dry I went to town with the Corraseal. I made up a collection of brushes to get into all the hard to reach places. The little brushes used for applying soldering flux are small, metal handle that’s bendable and hollow so a piece of ¼ all thread rod fits snug into it making for a long skinny brush bent at an angle on the end it able to get almost anywhere. The Corraseal turns the rust black in 15-20 minutes. Ready to paint the next day with out any more brushing or prep.
As with any rust treatment, the better the prep, the better the result. Wire wheel on a 4” side grinder is my preferred prep but that doesn’t get into the tight places. I’ve jammed wire brush handles into pvc pipe for extensions. I’ve brazed cleaning brushes for copper fittings to pieces of ¼ all thread rod. Also. I’ve even brought home from work boiler tube cleaning brushes with the extension rods for getting up into the frame.
Admiring your follow through and workspace. Taking notes ^^. I've been using a HEPA vacuum when I can to pick up the death flakes....
What do you place underneath your work area to catch the Ospho drippings / corraseal. A metal pan ?
I use cardboard. When the drippings dry it goes in the recycle bin unless it's saturated then it goes in the trash. I have used old shower curtains and curtain liners also.
I work outside on a slab so the rust dust blows out onto the lawn. And what doesn't gets swept up and into the trash. I'll hold my breath and with an air hose blow and other dust off the slab. It rains often in Miami and it washes right in. I don't think rust hurts the environment. When I Ospho parts by themselves it's usually on a plastic trash bag held down with some metal strips so it won't blow away. I'll hang some parts off a saw horse over the bag. The bag goes in the trash and I do wash off the Ospho with a hose on the lawn. I spread it around and haven't killed any grass but Miami grass is pretty hearty. St. Augustine grass. I guess the Ospho isn't good going into the ground but I just don't know and it really isn't very much. By the time I was it has almost dripped dry.
