RevISK
And that discrepancy seems fishy too...
I’ve got 4* in there now, looking like I need some 8* shims?Looks like -1.6 and -1.5…
Concur?
4* shims should put you in the hood, or even 5*.
I like to measure the ground level from tire to tire. For instance, a straight, 6’ 2x4 will even out the grounds “level” to give you a slightly more accurate reading.
Ok, I was pretty sure you did so either they’re installed backwards or something else is up that we aren’t seeing.I’ve got 4* in there now, looking like I need some 8* shims?
Seems really bizarre to need that much, don’t think I’ve ever heard of anyone installing that big on a 40 series?
Yes more “accurater”. And you’re imputing a lot of potential error using the square on the (not so) flat side in all four locations. l can see it. Likely need something that is an actual “straight edge”.. (if the blade of the framing square is hitting you likely need something like the steel rule from a tri-square)“If you zero your gauge on the ground under the knuckle then take your measurement, it will be less confusing.”
That shows a net of positve 2.5 degrees of caster. Your measurements here compared to the previous ones show that your methods are introducing error.Here’s my measurement while on my lift right after the spring install, so no shims, using the similarly inaccurate technique (I only took one side):
Well I think the twist is really only .3*. Since the little arrow on the angle finder is pointing up on one side and down on the other, they’re oriented the same way because the way I’ve taken the photos has the angle finder in a mirror image situation. Setting it to zero on my work bench, then putting the angle finder on a spare shim shows the same degree measurement, but the little arrow is pointing in the opposite direction when the angle finder is facing 180degrees differently. Man this angle stuff makes my brain hurt.yeah, that's wonky for sure. I am not sure what amount of variance is acceptable, but you have one positive caster knuckle (passenger) and one negative caster knuckle (driver). I would bet that an alignment rack would show slightly different numbers because it is going to be much more accurate compared to these tools. In my opinion shims are not going to change a 1.9 degree twist. Maybe @Pin_Head can chime in here
Agree to disagree. Did you zero out under each knuckle?Well I think the twist is really only .3*. Since the little arrow on the angle finder is pointing up on one side and down on the other, they’re oriented the same way because the way I’ve taken the photos has the angle finder in a mirror image situation. Setting it to zero on my work bench, then putting the angle finder on a spare shim shows the same degree measurement, but the little arrow is pointing in the opposite direction when the angle finder is facing 180degrees differently. Man this angle stuff makes my brain hurt.
Thinking it through, I’m seeing 1.1 degrees positive caster on the passenger side, and .8 degrees positive on the driver side. I’m feeling a little better about this with everyone’s input. I ordered some 6 and 8 degree shims to try out.
Here is what I mean about the arrow, (also these photos show the impact of dirt as the reading are different numerals, but the shim is pretty dirty:
I definitely would appreciate someone checking my work here!Agree to disagree. Did you zero out under each knuckle?
You can’t rotate/mirror the angle gauge after you zero it. Your shim experiment proves that.
Edit: I’ll be at my shop in a few hours and try what you are doing with my angle finder. If I'm wrong, I’ll eat my words.
