Personally if you are going to go through the trouble of installing the new clutch, I'd follow the directions on here and mod it or just buy one from
@landtank or
@NLXTACY Sure, your temps are moderate, but what if you find time for a trip to Utah or something? If so the stock blue hub doesn't have a great track record.
That was my assumption as well. I bought the truck out of San Diego, and against my wife's wishes I store it indoors for winter. I want to keep my rust free rig just that. I also have some driveline vibes that I need to diagnose. hoping its an easy grease job on the u joints on the DC shafts.
Unless your shafts are aftermarket they aren't DC. Should be easy to grease as long as you can orient them the best direction. This will require some trial and error... when I was full-time AWD I liked putting the transmission or transfer case in neutral then lifting one rear tire slightly and supporting it on a jack stand, and CHOCK THE TIRES. Turning this single airborn tire (there will be resistance due to the viscous coupler in the center diff) allows the driveshafts to be adjusted slightly without having to move the truck back and forth.
Before you grease each joint, check for reddish-brown dust coming out of the seal on each of the 4 legs on each joint. This is indication of a bad joint that grease won't fix, and it's time to start planning a replacement. I only bring this up because you describe vibes.. there's a good chance you have at least one bad joint already.
Also your front shaft is supposed to be out of phase. Don't be alarmed.
reading the stop with cardboard test .. is there any " measure " of how much resistance fan clutch should provide let's say @ idle with a normal operative temp engine .?
Not really.. it depends a lot on the individual clutch, how it's set up, and the temperature of air flowing over the clock spring on the front of it. My modded blue-hub could be stopped by hand in cool weather -after- the initial "roar" upon startup. This is with 20kcSt fluid and a 95F opening temp.. and NO problems keeping the truck cool even in very hot weather.
