So my 92 FJ80 with 196k on it failed smog today across the board pretty much. I knew this would happen moving to California but came anyways.
In my Visual inspection i failed the following;
Pump Air injection (missing a hose from the smog pump)
Vacuum lines sensors/switches (not sure what this is?)
EGR (the air switch valve wasnt working, EGR valve was. also most of the little hoses going into the EGR were cracked wide open)
Ignition timing (guy claimed he couldnt find the timing marks so failed me)
On the emissions test i passed the 2500rpm test but not the idle. One my idle was high at 1k. The truck sometimes does this, usually at start up it idles high and then comes down over a few minutes.
for HC i was allowed 120 i measured 275. for CO i was allowed 1.0 i measured 1.32
So, obv replace the missing hose, broken hoses and fix the timing but what else? The air switch valve is like $489 online, dont really want to pay that.
