Decided to try and follow the bjowett post https://forum.ih8mud.com/80-series-tech/58626-fzj80-oil-pump-drive-gear-bearing-removal.html and make a tool to remove the unobtainium oil pump idler bearing.
I made the body from a galvanized 1.25" to 1" reducer coupling capped with a 1" plug drilled to accept the bolt (absolutely the perfect size):
I'd found a washer just the right diameter, backed it up with a slightly smaller one for support, but obviously (in hindsight
) didn't get enough support:
Since I didn't check progress until I'd given it a few good turns, I've now destroyed the bushing:
SOOOOOO - how do I get it out now? find a grade 5 (or 8) washer the right size? have something machined? pray I wake up and this was all a dream?
Suggestions?
JP
Suggestions?
JP
