Factory receiver hitch rust!!
Ambridge, PA
As the title states, my factory hitch on my 93 is extremely rotted but only on the pass side by the exhaust...does anyone else have this issue? And can it be attributed to the moisture of the exhaust? As I said, the drivers side is nice and solid, but the pass looks like Swiss cheese...
It's possible but could be a result of any number of variables. Obviously the biggest concern should be is it safe to tow with?
I know they weren't "factory" but were sold with the truck when new...
It's not safe at all to tow with, will need a replacement if I plan to tow(wouldn't put a bike rack on this thing)
The only weird thing is that it's ONLY the pass side...
Mine was on the driver's side. Combine the two for 1 good one!
Mine is on the DS. I attributed it to salt on the road from passing cars, but the rest of the truck has NO rust on it, yet the 1/4" plate on the side has a 1-1/2" hole rusted through it!
I considered taking it off, cutting off the end plates and making new ones and welding them back on, but it will be easier to buy a new one from Draw-Tite (41015) thru e-trailer.com for $227.95.
I was shocked when I discovered it, considering I had just towed my classic car with it about a month prior to finding the issue! I could have lost both!
Almost all of the hitches I have removed, Valley or another brand, have flaking paint which leads to surface rust.
Do you have any that are worth shipping and using? I can do my own blasting and painting.....
My son and I work on exotics In Chicago as a hobby, yes they do drive them In the winter and people with heated garages have the worst rust on the undercarriage. So the exhaust side will have some rust as a result of that on our L/Cs. My body mount above the cats Is covered with rust and the rest of the frame is nearly rust free. Fun to work on.
I got a Curt hitch when I purchased my LX. Within the first few months the powder coat starting flaking off. I was able to return it for a new one, but the same thing happened during the following years. Two years ago, I sandblasted the damn thing, coated it with what was supposed to be one of the best rust coatings (can't remember name at the moment), and it now has started rusting again. :bang:
I am not understanding, can't you do this to your existing one? Or is it just too far gone? (Not that I don't want to sell one, but I rather people not buy something they don't need). I do have some aftermarket ones currently. http://www.cruiseryard.com/80-series-hitch/
The hitch on my '97 is only mildly rusted and I've been keeping that down with a coat of Fluid Film the first year, and a coat of LPS #3 the second. So far it hasn't spread as far as I can tell.
I just threw a near perfect trailer hitch away when I moved, on a Texas truck its whole life. I tried to give it away on our local club page for months. Funny how location makes such a big difference in need.
I know right?!! I had a mint condition one on my 95 but junked the hitch as soon as I lifted it.
Funny thing is the 95 has rust on my body, but not frame
The 93 has no rust (except the hitch) but the rear axle is rusted pretty bad :(
Mine has a hole rusted completely thru it on one side and heavily flaked on the other. I won't even tow anything with it until I replace it.
I see the one on your site is a different brand. Do you have any of the "original" hitches? They tend to follow the curves a bit better that the newer ones. I have a concern for clearing the spare underneath. I also have receiver for a wheelchair lift that has to go all the way thru the receiver for adjustment purposes.
I looked in classifieds a few times, but apparently most of those are made of gold.
Are the bolts that secure it put on with nuts or are the put on with inserts? I am trying to remove mine now. I'm not sure if the bolts are corroded or if there are nuts on the other side.
Unless you have a unique one I have not encountered, all of them will bolt/unbolt from the bottom into the frame. Either use an impact gun hooked up to a compressor or a large breaker bar to free them. Should be straight forward.
Mine was rusted party bad too. I had sanded down the rust and repainted a few years back.
