factory ps steering upgrade?
Boulder, CO
factory power steering upgrade?
I've been searching and have found a lot of good info, in posts and in the FAQ, but I'm not entirely sure I have my answer yet. I've got an 81 fj40 that came with factory power steering. I'm SOA and running 35's, lockrite in front. I have noticed while wheeling that's it's a real PITA to steer while aired down in 4 lo and not moving much (or at all).
My question is, can I swap in a saginaw pump and keep the stock steering box and make it easier to turn the wheel while on the trail, or do I need to do a saginaw box as well? It seems from my research that this is feasible, but like I said, I haven't found a definitive answer yet. Thanks in advance.
:beer:
You can swap in a Saginaw pump, but it is not going to give you the results that you are looking for.
Lockers and larger tires are not an ideal combo for stock, or stock style(mini-truck swap) power steering.
That's kinda what I thought you'd say Poser...
I will likely then go full saginaw when I do it so that I get the results I'm after. I'm also considering going with bigger tires down the road, and I also figured that I'd need full saginaw if that was in the plans. Probably do high steer then too... speaking of which, what's the favorite high steer kit, Marlin or 4x4labs ?
Luke at 4x4 Labs makes some very nice products....
If I were running a Toyota front axle, I would likely have his steering components on my junk.
I have installed his steering system on a SU 40 series and it has been working great. I like the idea of the tie rod being behind the axle, rather than on point.
There are also many happy Marlin Hysteer customers out there.
:beer:
Let me know when you pull that stock system. I will be glad to take it off your hands. (for a cash settlement of course.)
you can use your toyota pump with the saginaw conversion you just have to adapt the lines .I used a toyota pump for saginaw conversion I did a while ago and it worked as well as the sag pump. you can also bump up the flow on your toy pump by opening up the inlet a bit doesn't help pressure but flow at idle is better.
saginaw all the way, well worth it and i secon dthe 4x4labs system been running it for a year now, nice
I don't mean to hijack this thread, but can you tell me more about this mod? Either online or via PM?
I'm having some problems with my rig at idle...
Thanks!
If you remove your pressure line from the steering gear and the pump, you will see a brass flare seat. This is the piece that the fitting on the hose seals against when you tighten the b-nut on the fitting.
This brass piece has a hole in it that the oil flows through. Removing this brass seat and increasing the diameter of the hole in the center of it will allow more oil to flow through it.
:beer:
I ran a Saginaw pump with a small pulley hooked up to a minitruck box...
It may have been a little better than the toyota pump (only driven a few trucks with a toyota pump and minitruck box.)
It was strong enough to rip my center arm off the frame because I foolishly :doh: ran 38.5" swampers with minitruck P/S.
I wouldn't consider it any sort of upgrade though.
Yes you can use a toyota pump. And as long as you get a saginaw box with flared fittings (not the more recent o-ring) you won't need to adapt any steering lines. (may need a longer one though)
Definitely worth getting the 4.5 turn box that only came with flared fittings.
I screwed around with what was cheap and easy to come by for a while. It makes a huge difference with big tires.
For the cost, it's a pretty nice upgrade while your at it to add a ram.
Does a toy pump have the pressure and volume to run a ram?
This brass piece has a hole in it that the oil flows through. Removing this brass seat and increasing the diameter of the hole in the center of it will allow more oil to flow through it.[/QUOTE said:
I think I've seen that mod somewhere around here... wasn't sure if that was what he was talking about.
I may just try a smaller pulley at some point. My problem may be heat related. I don't have any problems when it's cold with turning at idle, but once it gets up to temp., it isn't as easy to turn. I haven't put the heat shield back on the PS gearbox since I swapped out the manual one. I have headers and it will have to be modified to fit but I just haven't gotten around to doing it. That might help a bit...
Thanks!
Just a thought, if you're going to all the extra work in swapping your stock P/S set up, I suggest adding a good inline filter to the low pressure line.
Check out the filters broncograveyard.com offers for P/S. It is a magnetic in-line that works in any cooler line.
As hard as the P/S system works, it needs a little extra protection.
Later.
Thanks!
Might want to try synthetic ATF... synthetic fluids don't change viscosity with temperature as rapidly as standard fluids...
