Quick question... I have the diaphragm from an F engine cooling system/waterpump and I noticed I did not put the gasket on the pic ( letter D) in the correct order.. I put the thermostat on the lower piece water outlet and then paper gasket on top then the upper water outlet piece with rubber o-ring.... The pic here shows the correct order -lower water outlet/paper gasket/thermostat/upper water outlet+rubber oring.. Is this a big deal? I did coat both sides of paper gasket with grey rtv and used new toyota upper and lower water outlets (so there nice and flat mating surfaces)..... Any thoughts?
