f-engine carb fuel delivery
Portland, OR
After selling the 40, which was driving and running perfectly, it started failing to deliver fuel properly. It started sputtering after the fuel got low and then wouldn't start after putting more into it. I'm helping him out with this as it seems the carb itself may be poorly rebuilt. Everything else in the fuel system is new. And vented. Fuel shows in the glass. It seemed at one point that the fuel wasn't atomizing. I'm thinking of swapping the carb altogether. Is there something easier to try? a better carb other than the stock?
Fuel low in tank or in carb? I would check the float for damage and needle first.
Verify Your Jets are not plugged or clogged with debris , especially your Primary one , If U have fuel level in your sight glass this
can be a likley point of restriction Post Carb Rebuild if the carb itself was not cleaned properly inside , If U suspect it was poorly
rebuilt this is a good place to start Related to a Fuel restriction Issue inside the carb itself as I understand Your above issue to be
Related to the " No Atomizing " fact U point to .......
after talking about it more my feeling is that he flooded the carb/manifold. Is it pretty easy to do that with these stock aisin carbs?
Matt if your rig still has a chinese dissy, I think you should consider switching to a made in Japan Nippondenso. I’m partial to this one with Pertronix added OEM 2F Distributor for '75 and Earlier Land Cruiser FJ40
You would also need a vac advance port on your carb.
Does the new owner know how to take a vacuum reading? Fully warmed at idle I’m at 18.5 on my sloppy 47 year old F.
I am glad you found a buyer. You have put your heart and soul into this rig. At some point you might be wise to tell the new owner about mud. They’re gonna need to take the reins so you can move on eventually.
I'm certain that dizzy is sorted out.... The condenser was bad and that's all it needed. That and an adjustment of the butterfly valve and the thing fires up in 3 or 4 cranks on a cold start. If it is the dizzy then I'll be getting that. It's out of stock on cityracer. Any other sources?
And is this the correct pertronix? https://www.amazon.com/Pertronix-91661-Ignitor-Adaptive-Cylinder/dp/B004OXT208?tag=ihco-20
He's gone on a trip but I told him to check the spark plugs to see if they are wet from fuel. Of course it will probably all evaporate by the time he returns and it will fire right up. He has no background with 40s but always wanted to own one. So yea, I'll probably help him out (for a little while). I'm going to go build a couple of fj45s in Costa Rica this spring, so I've definitely got plans to move on!
I’m not sure how the II(2) works compared to the I(1) with that dissy. From my investigation I discovered that Mark’s Offroad has been installing Pertronix’s for years. Working off the assumption he’d send me the best setup, I ordered from him. He sent me the ignitor 1. I didn’t ask him why. He loves those small caps and may have one in stock. He has a slightly different way of hooking them up than the Pertronix instruction sheet. All I know is I’ve got rock steady 18.5hg’s vac a idle now, gobs of snappy power in all 3 gears, and only need a minute of choke(cold weather only). I’m sold on the setup Mark has so graciously informed mudders about. All on a 47 year old engine:cheers:
