I am looking to have the exhaust on the LC redone. One thing I want to do is either move the cats to the inside of the frame or do a single high flow cat. Going with a single high flow where would the O2 sensors be placed? When I was into the smaller imports I used to run 2.25" exhaust, what are people running on the LC's and seen good results? Would you also eliminate one of mufflers/resonators and just have one muffler? Please post up your pictures if you have done the above mods and what results, recommendations you have.
2.5" piping is ideal for an NA 1fz. The rest is just a matter of preference. I like mufflers and resonators--the truck is loud enough just rolling down the highway.
I am really on the fence about doing this mod, was thinking it could help the engine breath which might help MPG but MPG and these rigs do not exist.
The real reason behind swapping it out, the exhaust on mine is the factory exhaust and is starting to show its age. There is a little rust but nothing like East Coast, Mid West rust...
Will in the future. I have Trail Gear sliders I want to install and really do not feel like having to fab up a front mount for the sliders to go around the cats.
Scott ... not sure how different the 94 exhaust is from the 96-97, but I just removed the rear cat and had a test pipe welded in it's place. It doesn't throw a code and now easily clears the cat protection on my White Knuckle Sliders.
I replaced my cats with the magnaflow cat and pipe that bolts to the manifold, removed the resonator and welded in a thrush dual chamber muffler. Not too loud or raspy, just a good deep, mellow tone cruising down the trail. Mines a 93. I moved one of the O2 sensors to the manifold where the PAIR valve used to hood to. I removed all that crap long ago.
I need to look into removing that PAIR stuff as well. Tried searching but really didn't find anything worth a damn. I will talk to a few local shops and see what they recommend as far as the exhaust.
If you are going to keep it smog tested in the Valley, then you need to keep the side by side cats, as they DO look for them with long handled mirrors. I have HEARD that they dont care about the PAIR system.
o2s in manifold, if you wanna get rid of the pair and not run o2s then grab manifolds off a 95 plus. Then I’m doing the double down pipe into a single followed by one cat like 95. After the cat goes over the frame just like our 94s do, then to muffler , then over the rear cross member going back towards bumper then pointed down. The only thing that could get smashed would be the cat but it’s tucked up high as can be. No resonator no exhaust hanging to the side and under the frame to smash. 700 or so bucks from custom exhaust shop. Sliders have no cat protection. I only have two legs holding the slider on the pass side cause never got around to building the third leg which would have had cat protection. My sliders are welded on and haven’t had issue in 12 years running no cat protection or just staying with two legs. I don’t know if bolt on would hold the slider as well.
Mines a 97 but I went with a single CAT, ditched the resonator and put a Walker Quiet Flow Muffler. On mine the Cat is outside the frame rail but I will be able to get the slider mount around it. O2 sensors are upstream of the CAT and the back near the center body mount just before I cross over the frame. No codes or issues at all. As far as sound goes it's pretty quiet, no whistle or anything like that. Pics in the link in my signature.
Post 4 is pure logic, which I know isn’t the norm around here. Get rid of those sliders and buy a set of White Knuckle Off-road sliders. Mine have protected my stock cats and I’ve beaten the tar out of them. The 1/2” thick cat guard is bent upward a little from hard hits but the cats are fine.
Recently, I went through the same decisions you are making now. My exhaust system is still very solid as I’m sure yours must be. My cats look damn near new inside. I was going to build test pipes but my respect for Mother Nature told me to keep cats and since mine are good to go I put it all back together with new bolts, gaskets and isolators leaving off all of those rattling heat shields. I did delete the nonoperative pair system and installed new O2 sensors in the manifold. Seems to run better. I ditched the resonator years ago and replaced the muffler with a Walker unit two years ago.
I don’t think there is anything considerable to be gained even with a 5” straight pipe.
"Like" didn't seem strong enough. There have been a good number of threads lately on fixing stuff that's not broken. Or "help me spend money unnecessarily"
Also rare to see someone make a choice to respect the earth and actually post about it on this forum. Seems the norm is "help me pump more crap into the air."
This, to me, suggests your exhaust is still good to go. Mine had a rusty appearance when I got the truck 5 years ago, but the pipes and muffler are all still solid, despite taking a physical beating from rocks and the driveshaft (don't ask). I also don't think you'll notice any seat-of-the-pants performance by removing a cat or adding a high-flow cat. High flow cats just have a less dense honeycomb that makes them "high flow", so they don't scrub the exhaust as well. Not much performance to be found, and as you state, mpg lol
I will confirm no noticeable difference in MPG or performance with the high flow single CAT. Only reason I did my exhaust is the muffler was about to fall off.
