Excessive maintenance on gx470?
South
Hi all I'm looking at an 07 gx470 with 125k on the clock. Good news is all service was done at the dealership but the amount of work done seems to be excessive. I've only copy/pasted the uncommon service (no oil changes, tire rotations). Does anything seem out of the ordinary? I'm somewhat concerned with the warped rotors and front brakes every 35k, cat 1 bank being replaced, and the stealership doing two timing belt changes within 25k of each other.
I'm also looking at an 05 with 12k less miles for the same price. Any preference in the 05 or 07? Both have the sport package. Thanks!
  • Mileage Service
  • 124832 BRAKES GRINDING GUEST REPORTS SHUTTER UNDER BRAKING AS WELL AS HIGH PITCHED SQUEEL NOISE - FRONT BRAKES PULSATING BADLY. - REPLACED FRONT PADS AND MACHINED ROTORS.
  • 121508 OTHERS XM RADIO SIGNAL CUTTING IN AND OUT WHILE DRIVING. GUEST REPORTS WILL COME BACK ON MOST OF THE TIME WHEN VEHICLE IS TURNED OFF AND ON AGAIN. - SEE PREVIOUS RO - TEST DROVE VEHICLE MULTIPLE TIMES, UNABLE TO REPRODUCE SYMPTOM THIS VISIT. BASED ON CUSTOMER CONCERN, POSSIBLE SATELLITE MODULE INTERMITTENT FAILURE RATHER THAN ANTENNA FAILURE. - NO WORK PERFORMED THIS VISIT
  • 118953 BATTERY LIGHT IS ON GUEST REPORTS BATTERY AND OTHER WARNING LIGHTS ON AND VEHICLE DIED WHILE DRIVING GUETS REPORTS VEHICLE JUST HERE FOR SERVICE - PERFORMED BATTERY AND CHARGING SYSTEM TESTS. FOUND ALTERNATOR FAILED CAUSING NO CHARGE CONDITION. - REPLACED ALTERNATOR AND RECHARGED BATTERY TO CORRECT.
  • 118699 OTHERS GUEST REPORTS SATELITE RADIO WENT INOP AFTER HEAVY RAINS - FOUND ANTENNA WIRE BROKEN - REPLACED ANTENNA ASSEMBLY TO CORRECT AND VERIFIED CORRECT SATELLITE OPERATION
  • 118699 DRIVE SHAFT BOOT (ONE SIDE) GUEST REQUESTS REPLACE LEFT AND RIGHT SIDE FRONT CV AXLE BOOTS PER LEAKING, - COMPLETED REPLACEMTN OF FRONT CV BOOTS
  • 118699 NONOEM THEFT DETERRENT SYSTEM INSTALL/R&R - GUEST REPORTS KEY CASE FOR MASTER KEY BROKEN. GUEST REQUESTS CUST NEW KEY CASE. - REPLACED MASTER KEY CASE
  • 118699 NON WARRANTABLE OPERATION CODE GUEST REPORTS ABNORMAL HUMMING SOUND FROM ENGINE AT START UP THAT LAST FOR SOME TIME - ADVISE - UNABLE TO DUPLICATE ANY ABNORMAL ENGINE CONDITIONS. ALTERNATING CHARGING CORRECTLY AND AIR INJECTION SYSTEM OPERATING AS DESIGNED
  • 103206 NON WARRANTABLE OPERATION CODE GUEST REQUESTS REPLACE WATER PUMP,FRONT ENGINE SEAL,IDLERS, TENSIONER,AND SERPINTINE BELT IN CONJUNCTION W/TIMING BELT - REPLACED WATER PUMP, CRANK SEAL, IDLERS, TENSIONER AND DRIVE BELT WITH SERVICE
  • 83070 BRAKES SQUEAKING GUEST STATES HEARS SQUEEKING NOISE UNDER BRAKING/SLOWING DOWN AT TIMES - ADVISE - REAR BRAKES WORN TO 3MM - REPLACE REAR BRAKES AND RESURFACE BOTH REAR ROTORS
  • 77610 NON WARRANTABLE OPERATION CODE GUEST REQUESTS REPLACE TIMING BELT,CRANK SEAL,AND DRIVE BELT IN CONJUNCTION WITH WATER PUMP REPLACEMENT - REPLACED TIMING BELT RELATED COMPONENTS WITH WATER PUMP REPLACEMENT.
  • 77610 INSPECT FOR FLUID LEAKS UPON INSPECTION FOUND COOLANT LEAK FROM WATER PUMP RGES - REPLACED WATER PUMP TO COORECT
  • 75834 SFI.MFI GUEST STATES CHECK ENGINE AND OTHER LIGHTS ARE ON - P0420 PRESENT IN FF MONITORTED DATA LIST FOUND BANK ONE CAT TO BE INTERNALLY FAILING NEEDS NEW - REPLACED CAT ASSY ON BANK 1 SYSTEM OK AT THIS TIME FP#17150 - 50050
  • 70925 BRAKES SQUEAKING GUEST STATES BRAKES SQUEEKING AT TIMES - FRONT BRAKES WORN TO 2MM - PERFORMED FRONT BRAKE JOB, TURNED ROTORS & TEST DROVE.
  • 44970 BATTERY LIGHT IS ON CHECK BATTERY LIGHT IS ON - BATTERY FAILED MIDTRONICS TEST - REPLACED BATTERY RESET ELECTRICAL
  • 38849 SFI.MFI CUSTOMER STATES RPMS NOT DROPPING WHEN COMING TO A STOP STAY S OVER 1K RPMS AT IDLE AND AT SLOW SPEEDS ENGINE ACTS LIKE IT WANTS TO GO FASTER AND AT HWY SPEEDS ENGINE FEELS LIKE IT IS HOLDING BACK LIKE IT DOESNT HAVE ENOUGH POWER ADVISE - NO PROBLEMS FOUND AT THIS TIME - TEST DROVE SEVERAL TIMES AND RAN SYSTEM HEALTH CHECK NO CODE S STORED WORKING AS DESIGNED AT THIS TIME
  • 34429 BRAKE VIBRATION C/S THAT WHEN BRAKING THERE IS A VIBRATION THAT OCCURS FROM THE STEERING WHEEL - FRONT ROTORS WRAPED + - MACHINE FRONT ROTORS TEST DROVE VEHICLE AND ALL VIBRATION AND PULSATION GONE
  • 1948 OTHERS CUST STATES CHECK ENG LIGHT IS ON, VSC OFF, TRAC OFF LIGHTS ARE ON - ENGINE DTC'S PO300,PO301,PO303,&PO305.MISF IRE AT IDLE TESTED SPARK PLUGS AND COILS.OK.FUEL CONTAMINATION FOUND - REMOVED ALL FUEL FROM TANK.PERFORMED FUEL INJECTION SERVICE FILLED TANK 10 DOLLARS.TEST DROVE NO MISFIRE IS PRESENT
Thanks. I was more concerned with the frequency of brake service, rpms dropping but unable to diagnose, and cat one bank failing. Though from my light research cat one could have also been a bad o2 sensor.
that sounds great! All the expensive stuff was done! I'd rather people over do the maintenance than none at all. Front brakes seem to have a lot of problems on these rigs for some reason. Mine were done several times by the prior owners.
Thanks for your insight. Have any gx owners moved to 5th gen 4runner calipers? This seems to be popular with the 4th gen crowd as its slightly bigger.
All of those services were done per the owners request, the dealer did sell the work... idk why two timing belts were done on it, but whatever it's their money. Brakes are notorious for being troublesome on these, the calipers stick, its best to replace calipers and rotors along with the pads when this happens. The cat was an unnecessary replacement, it only needed an o2 sensor. I wouldn't worry about any of that.
They write it up as 'Customer Requests', but could certainly be that they are requesting it based on what the dealer is telling them it needs. Seems to have some odd electrical gremlins.
Abnormal humming during start up - we call that a clutch fan :) Perfectly normal - but also tells me this is an owner with very little knowledge about the vehicle, so they wouldn't be smart enough to request all of those other services without being persuaded to.
Warped brakes, also normal.
Replacing a cat at 75k? Definitely NOT normal, and also leads to believe the owner continued putting crap gas in the car since day 1. Those are the things that would make me hesitate to buy this one.
Thanks everyone for their insight. Any preference between this and an 05 sport w/ kdss for the same price? It has 13k miles less. From what I can tell all the refinements between 05 and 07 have been cosmetic.
I would closely inspect the frame also, and find out where each came from. I'd take a 150k vehicle from North Carolina every day over a 75k vehicle from New England. Many vehicles for sale down south have been bought in auctions where the cars came from the north.
Will do. Both these vehicles are central texas natives.
How do you like the KDSS? Do you think it adds a worthwhile premium to pricing? How high are you lifted with the KDSS?
I love KDSS. Once you get past the annoyance of getting sliders that will work, it's a great option. Rides like a sport car on the street, and plenty of added travel off road. Best of both worlds really. I'm lifted right at 3". I consider it a bonus though, and wouldn't necessarily pay a premium for it. When I found mine, it was obvious they had no idea what it had, since it was priced lower than most others I found that didn't have KDSS.
Replaced cat could have something to do with the sulphur smell in the exhaust. I assume the gx had this problem like the T4R. 80k was the emissions warranty limit. Or stolen cat?
