- Thread starter
- #81
Now the main exhaust system was complete, I needed to add a balance pipe at the front. Now normally you have the balance pipe in the middle of the car (after the cats but before the mufflers), but obviously with this design the exhausts run down the outside so this isn’t possible.
Instead, I decided to add the balance pipe under the sump at the very front of the engine.
Using 1.5” stainless mandrel pipe, I added the first flange port on the drivers side….
Next, made up a bend pipe to join the flange…
Had to create the matching passenger side port, as you can see it took some “interesting” angles to make it work. Luckily the end of the belt sander is roughly the same size as the diameter of the exhaust pipe, so was able to shape the pipe to roughly the right shape.
Didn’t grab a pic of lining it up, but here is welded into place.
Needed to “cut” out the existing pipe… On the first one I used drill bits and milling bits which was bloody hard work. Decided on the passenger side to cheat a little and use my ability to blow holes with the welder…
Cranked the welder up from ~60amp to 200amp and blew the metal out in about 6 seconds vs the 20 minutes it took on the drivers side lol.
