Now for the next section I used 200cpi high flow stainless steel cats and quality stainless steel mufflers. Technically speaking I didn’t need a catalytic converter as the engine predates the requirement, but I prefer the safer co2 emissions that a cat provides (Being a convertible that does lots of slow speed off road driving, you get exposed to a lot of exhaust gasses, would prefer CO2 to CO and HC).
I welded the cat directly to the muffler as there is minimal space, so hopefully that doesn’t cause an issue.
Held the new cat/muffler section in place and created the section to join to the front of the exhaust and the cat (Couldn’t get a picture of this as it was hard enough trying to hold/align everything without trying to take a photo), but here is the result
Bolted everything up, looks good. Nice ground clearance as should have enough clearance from the chassis. I am worried about heat radiating into the cab, but will install some heat shielding down the track. If its bad enough I might add some HPC coating.
Once I was pretty happy with the passenger side, I started on the drivers side. This was a lot harder as there is a tailshaft and power steering box to deal with. Now there wasn’t enough room to come out on a normal 90 degree bend, so I had to cheat a little and cut the mandrel bend on an angle (rather than square) which increases the rate the pipe changes direction. The downside to this approach is the pipe is no longer “round” as the cut angle makes the pipe “oval”. So I had to grind the flange into an “oval” shape to match the pipe, which is a very time consuming process. The first bend took around 4 hours to get right, but the result is maximum clearance to the tailshaft. (It’s really hard to tell in the photos, but the extra angle saves a good 40-50mm).
I also used this trick a bit more on a few other tight bends, although was a little faster as the pipe is easy manipulate with the belt sander vs the thick flange which required a file/milling bit.
I followed the same process as the passenger side till I ended up with the following…
From the point of view of the gearbox output flange, you can see where the tailshaft roughly runs to the diff and how much clearance there is to the exhaust. So shouldn’t have an issue…
