- Thread starter
- #121
So the plan is to weld the bolt to a separate piece of steel, then weld the steel to the housing. This gives 2 advantages, firstly the bolt will come out “smooth” from the housing (as the welding will be on the inside) and secondly it gives a “recess” for the pop rivets to hold the LEDs in place, meaning I can cover the hole in silicon which wont be visible. It’ll make more sense in a second…
Cut out 2 plates with holes/recesses for the pop rivets.
Then drilled a hole in the center for the bolt to fit through. Yes it very much looks like a face lol…
Feed the bolt through the hole and drilled a corresponding hole in the housing.
You can see how it mounts together now
Welded the bolt to the plate
Then clamped the plate/bolt to the housing
And welded it on.
Ground it smooth
Test a did assembly…
Once I was happy with the main body, I got some round tube (50mm from memory?) and cut it on a 30 degree angle (which is approx. the angle of the front guard sloping down) and welded an end cap on.
Ground it smooth and drilled a hole in the middle.
Now ready for a trial fitting. (The LED looks bright, that’s only from the flash of the camera). You can see the guard which has been prepped for painting
Testing the indicator light
And the parkers/parking light
Overall I am pretty happy with how these turned out. Can’t wait to see what they look like painted/fitted.
And welded it on.
Ground it smooth
