- Thread starter
- #41
Next problem to overcome with the aircon/alternator setup.
The aircon compressor and bracket sit quite low in comparison to the engine block, which means on full suspension compression the top of the diff pumpkin will hit the bottom of the aircon compressor. This is super frustrating as we didn’t pick up on the height issue during initial visual inspection (We were more focused on it hitting the chassis rail on the side or the steering shaft).
The other problem is the clearance around the alternator. There is no way it will fit in its normal position (On the passenger side), but we were hoping to rotate it upwards on the original top mount.
This works with the 308, but it gets very tight with the intake on the 304. It also has limited movement to act as a belt tensioner.
So it was time to get creative….
Firstly the aircon compressor had to be moved up to make clearance. Rather than reinventing the wheel we essentially wanted to reuse the standard bracket as much as possible but just reposition how it mounts to the block. We started by physically holding the compressor in the right area and drilled a new hole to bolt up to the head.
This seemed to give enough clearance to the steering shaft and outside guard. As we were using the same mounting bracket in roughly the same position is meant the belts should line up.
This was also a good opportunity to relocate the alternator from the passenger side to the drivers side above the aircon. The major benefit (Apart from the fact it physically fits) is it keeps the alternative high and out of the water/mud. The problem with this design is the belt path is going to clash with the radiator top hose.
Once we had it all jigged up it was time to make a mounting plate to reuse the head mounting points.
After some cutting and grinding it fit nicely. It was then just a matter of drilling some mounting holes (which is easier said than done). Using the “eye/guess” method we got within ~2mm which is pretty good.
We then bolted it up to the block and tack welded the two brackets together.
Then it was just a matter of pulling it off and welding it up properly.
A few of the welds were a bit blotchy, but remembering I only learned how to weld not that long ago and have had minimal practice I was pretty happy with the results.
You can now see the bracket bolted into place.
Once the alternator bracket was marked, we marked and cut the main bracket.
