Build Engr Build Thread
Tall Corn Cruiser Classic 2022
Low range gears are awesome- increased downhill control with engine braking and relying less on brakes and also crawling up steep inclines with minimal throttle input.
Been getting 13mpg highway on the recent trip to northern MN
Looking like a blown head gasket after our trip to Colorado.
I got the pickup engine rebuilt and running so on to the next thing! Sometimes it's nice having multiple project vehicles, other times it is not....
Forums and YouTube would lead you to believe that the upper intake bolts are hard to get to... Didn't seem that bad for a 93.
Drivers side wheel well with a swivel, 12mm, and ~24in of extension.
Took 5 minutes
Pretty much every 30 year old plastic connector I've touched has crumbled the push tab. Going to be more of a wiring pins project and less of a head gasket/smog delete project
Toyota puts the part number on the connector.
Head is off. Cyl 5 is steam cleaned. Fire ring is toast. Hone looks good
Have a few more connectors on order and need to figure out what to do about the 90980–10184 Water temp/ECT cut off switch.
Harness is done. Had an egr blocker plate project on the mill. Head is on with ARP supra studs and oem gasket
Intake side is done. Exhaust flange studs won't budge. Still need to make a blocker plate for egr valve
Still working on these studs. Probably going to a bolt and nut
A PAIR cap and intake EGR blocker plate machining project away from running again
245,300 miles
OEM Head gasket
Arp head studs
All new small rubber hoses
Pcv valve and hoses
Water pump, thermostat, heater control valve, PHH
Fuel filter
Desmog PAIR and EGR
PS pump reservoir
All OEM gaskets in top end rebuild
Oil cooler and intake manifold cleaning
Engine hardness wrap with Tesa and new electrical connectors for IACV, ALT, Inj, coolant temp, knock sensor
Injectors cleaned by mr. Injector
Oil change and filter 😁
New coolant
Take your family on trips and use their comments to justify upgrades.
1UP USA added 2 new racks
Dobinson MRAs to fix the bumpy ride
Family suggestions are the best upgrades haha. Your post on the led dash light upgrade I saw you put leds in your hvac console would you happen to remember which lights you used?
I believe they are type B
Shakey mirror foam, floppy mirror bolts, tape, and ultimately the whole plastic motor assembly cracking and falling out, just ended up replacing with OEM. I think they are for RHD though and my driver side mirror is playing with my eyes
