- Thread starter
- #61
Well at the end of the day, is this a machine for offroading, to go out of the country, like mexico and middle america? Or a road type machine to pound the pavement?
If it is more a machine to pound the pavement. Then do the extreme stuff. If you want a reliable build that works well in Mexico or middle america or travel up north. Stick with the less extreme mods.
I have ZERO interest in ever going to Mexico or any South American country. So that narrows down things for me
Of course Canada and Alaska is definitely in my sites!
Forged pistons do not mean that much even when the engine detonates at the wrong time, they still will get hurt. So if you want to play with higher boost pressures and aftermarket fuel management systems. go for it, but remember, horse power costs money.
The forged pistons issue is something that has stuck with me back in the days when I was building road rockets out of a SBC. Forged was the way to go. I don't want to make a 1/4 mile tractor. I do want something reliable but with plenty of oomph when I want/need it. I can easily be talked out of forged if all the motors you have been building all use the stock pistons. I just saved a grand right there.
A close friend here in the front range has a 1fz with stock 1mm over pistons(pistons, rings, crank, rods, block all cryo treated). He typically runs 10-12psi boost in his 80 series(has a few different pulleys). Stock fuel system, stock fuel pump. Plays with a O2 sensor enrichment(If I remember right). Has a copper gasket(back before we new about cometic). He built the engine him self, maintains and play with it. He is an old motor head and tinkers a lot. Problems I hear from time to time, predetonation or a miss. Keeping cats that will work with local emissions is a major pain(burns them out every other year). He takes this truck hunting every winter in the high moutains, flogs it, and makes it work hard. It really has not missed a beat.
This is 100% NOT me.
Stock pistons are not a problem, neither are the rings(top is stainless, great for forced induction engines). All of the OBDII engines with superchargers I have put together are working well still. a couple of guys with stock engine componets with Turbos are doing great as well. I do not see needing the extra cost of forged pistons unless you are going the route of messing with some aftermarket fuel management system(a major cost).
The only items I am playing with is upgrading the fuel pump, modifying the throttle body (ok its not really fuel side), staying stock flow injectors for the time being but may go with an adjustable fuel pressure regulator. If I need to bump up the injectors I can do that relatively easily.
If you are planning on traveling out of california, keep it mostly stock and simpler. Other wise invest some major time in learning all you can, so when the truck has a bad day. You are able to take care of it. Because unless you are close to the builder or tuner to have him figure it out. You will be up sh*t creek with out a paddle. Keeping it simple for traveling is a better idea in my mind.
Good advice which is why I didn't want to go completely nuts with this.
Either way, I need to find a good LOCAL tuner to help me dial this beast in. Thanks for the input Robbie.
