Agreed, sounds like a fun project, and one I'm pretty familiar with as well! Robbie (Powderpig on the board here) came out to my place last year and did a full rebuild for me; this is what we came up with:
*Compression - stock (block decked .010, standard thickness Cometic head gasket)
*ARP head studs (the kit for the Supra 2JZ)
*Cylinders bored +1mm, new Toyota pistons/rings/bearings/etc.
*Still using the stock fuel pump, may go the Supra route at some point but see no need for now
*Stock injectors, cleaned and flow matched by Witch Hunter
*TRD SC, now running a 2.8" pulley and "homebrew" water/air intercooler setup - highest boost I've seen with this combo is about 7.8 psi
*I went ahead and powdercoated the valve cover, so far it's holding up great. Exhaust manifolds were ceramic coated and the air filter canister I just had sand blasted and then painted with some rattle can "high temp silver ceramic" paint from VHT. I didn't want to ceramic coat this piece because after sand blasting it was clear that it is held together partly with some sort of epoxy that seemed like it might melt in the 400+ degree curing oven.
After putting 11,000 miles on the truck in the past year, I can say I'm very happy with the way the rebuild turned out. The power is very nice and the delivery is smooth. Running 315's with stock gears and I can easily maintain 75 mph up any grade, even fully loaded and with a 1,500 lb trailer in tow. A few other things I can recommend that will keep the truck happy with the supercharger setup:
*PLX digital EGT/Boost/AFR gauges - these are awesome and I love the flexibility to daisy-chain additional sensors and display up to 4 of them with only one 2 1/16" gauge so the dash remains relatively uncluttered
*Upgraded transmission valve body - I'm using a modified valve body from IPT since I had it left over from my previous 80 that was wrecked. If I had it to do over again I'd probably go with the Wholesale Automatic extreme valve body now that they are available stateside, but the IPT made a huge improvement over stock as well.
Good luck and hope the info helps!
