Will Van
GOLD Star
- Thread starter
- #41
Have you had them out to check?
The oiling issues on those motors are well established. Changing bearings doesn't stop the problem, it just resets the clock.
I'm confused. It was my understanding that the "BEB issue" was a series of years (1990 to 1994?) where Toyota used inferior bearing material between the crankshaft and connecting rods, and the factory bearings deteriorated prematurely. Supposedly swapping to ACL, Taiho, or updated Toyota bearings resolved the issue.
But it sounds like you are saying that the BEB issue was actually due to a faulty internal oiling design that supplies oil to the BEBs. And that the BEB oiling was redesigned between the 1HZ/1HD-T and the 1HD-FT generations. Is that correct? Can you elaborate on what Toyota redesigned? I thought the crankshaft was identical between 1HZ, 1HD-T, 1HD-FT, and 1HD-FTE?
