Ok ok i don't know much about electrical systems.
Cruiser was running fine. Then turned it off. Turn the key to start it...nothing. no power at all. No gauges, no lights, it's as if the key wasn't even in the ignition.
2 hours later try again. Turn key cranks right up. It starts up. Turn it off.
Try again ... nothing.
And Now it's dead again...next day. No change.
Recently replaced battery, battery cables, and starter.
Thinking is ignition, I unplugged the 4 wire ignition switch under the dash and plugged in a new one and turned it manually and nothing. Not sure if it has to be installed in the steering column to function properly.
Any ideas? Help much appreciated!
