EGT Temp Guide
Initial run of my recently converted 1996 FZJ to HDJ. Pretty much effortlessly cruises at speed.
Model: HDJ80
Motor: 1HD-FT
Turbo: Yes, GTurbo Grunter Extreme
Intercooler: Yes, Safari FMIC
Tires: 315/75/16 BFG AT KO
Exhaust: 3.0" Inside Frame Straight with Aero Muffler, exits just behind tire
Egt probe location: Pre-Turbo
Trans: 5 speed H151F
Diffs: 4.88 ARB's
T-Case: .90 OD Hi Range, 3.1 Lo Range
Cruising Data:
Speed: 65 mph (102 kph)
RPM: 2850
GPS or Speedo: Speedo, GPS corrected
Av. Temp: 75 F (24 C)
Altitude : 400' (122 M)
Boost: 10 psi
EGT Temp: 400 to 450 F (205 to 232 C)
On a decent prolonged climb over 1000' pass, easily held 65 mph, EGT topped out around 900 F (465 C)
Cruising Data:
RPM: 2850
They're some pretty high cruising RPMs. What sort of fuel economy do you see at that speed?
you would like to go down on R&P with your manual transmisión .. I'm moving same 315 ( same size at least ) with stock gearing and H150
To be seen, as I am on my first full tank post-conversion. Filled up 50+ miles ago, and the gauge has yet to move. Either it is stuck, or the rig is sipping fuel.
Model: HZJ60 (8/85)
Motor: 1HZ (96 JDM)
Turbo: Yes, Garrett GT2860RS "Disco Potato"
Intercooler: No
Tires: 31-10.50 R15
Exhaust: 3.0" Outside Frame Straight with Muffler, exits just in front of rear tire
Trans: 5 speed H55F
Diffs: 3.70 stock
Cruising Data:
Speed: 63 mph (100 kph)
RPM: 2100
Av. Temp: 68 F (20 C)
Altitude : 460' (140 M)
Boost: 5 psi
Max Boost: 12 psi
EGT Temp: 500 F (245 C)
Rig data:
Model: 1983 BJ42
Motor: 3b
Turbo: Yes- Jefferson State Machining Kit
Intercooler: No
Tyres: 33x10.5
Exaust: 2.5"
Egt probe location: Pre turbo
Trans: 5 speed
Diff: 4.11 (std)
Curising Data:
Speed: 60 mph (97 kph)
RPM: 2600
GPS or Speedo: GPS
Av. Temp: 80 F (27C)
Altitude : 700
Boost: 7psi @ above cuising speed
:Max set point-10.5 psi
EGT Temp: 750deg @ above cruising speed
:Max 1050deg pulling steep grade
Model: 1990 Hilux Surf
Motor: 2L-TII (mech injected) EGR deleted, throttle plates gone, boost compensator tweaked
Turbo: CT20A
Intercooler: No
Tires: 31x10.50R15 AT
Exhaust: 3" mandrel downpipe and to trans x-member, 2.5" crush bent the rest of the way back through Magnaflow muffler
Egt probe location: Pre-turbo
Trans: 5 speed R150F
Diffs: 4.30:1
Cruising Data:
Speed: 115km/h
RPM: ~2800rpm
GPS or Speedo: Speedo, corrected for difference in tire size
Av. Temp: 2*C
Altitude : negligible
Boost: 5-6 psi cruising
Max Boost: 11 psi
EGT Temp: 500-600*F cruising 115kph, 900-950*F maintaining 115kph up hills, max I can seem to get it is 1275* in 5th, floored, for a good chunk of time, at 135kph.
Rig data:
Model: LC 80 - 1993
Motor: 1HDT
Turbo: Yes- Stock Ct 26
Intercooler: No
Tyres: 285-75-16 MT
Exaust: 2.5"
Egt probe location: Post Turbo
Trans: 4 Speed Automatic
Diff: 4.11 (std)
Boost: Stock Turbo
EGT Temp: 600c if up hills or when Pressing Hard - Other wise 300-350c
Rig data:
Model: FJ60/HJ61 hybrid
Motor: 12h-t
Turbo: Yes (gturbo)
Intercooler: Yes (pdi)
Tyres: 33s
Exaust: 3'' Including dump pipe
Trans: 5 speed manual
Diff: 4.11 (std)
Curising Data:
Speed: 65mph / 105 kmh in 5th gear
RPM: unk, tach not working
GPS or Speedo: gps
Altitude : 2000' / 610m
Boost: 15 psi
Max Boost setting: 18 psi
EGT Temp: 737F / 391C
First video is on flat/rolling hills freeway at 65mph/105kmh :
Second video is going up a long incline:
Rig data:
Model: BJ75
Motor: 14B-T
Turbo: Yes - Stock CT26
Intercooler: No
Tires: 255/85/16 (like 33x10.5)
Exhaust: 2.5"
EGT probe location: Pre turbo/Exhaust flange where turbo is mounted
Trans: 5 speed - H55
Diff: 4.11 (std)
Cruising Data:
Speed: 110 km/h (63 mph)
RPM: 2350
GPS or Speedo: Both
Ambient Temp: 68 F (20C)
Altitude : 2700 ft (822 meters)
Boost: 7.0 psi
EGT Temp: 860 to 950 F (450 to 505 C)
With FMIC / Verification with round dial speedo and GPS Speedo.
