ECU location by model year
Does it have an internal battery? Any extra boxes up under the driver's side dash, near the steering column?
Ok, so I've found out it's a VIP S1000 unit.
Gonna axe CDAN.... but WHY DOESN'T IT AT LEAST LIGHT UP WHEN THE GREEN BUTTON IS DEPRESSED?
Is the unit even plugged in? The harnesses should be coming out of the hole In the carpet under the seat and plugged into the control unit.
Yes, it is. It has a larger harness (9 port?) that is plugged up, and a smaller side plug that has nothing plugged into it. Also has antenna (I assume) plugged into it.
Do you have access to a voltmeter? Perhaps the line to the control unit doesn't have power running to it. If you can trace where the line is plugged in or spliced into something else to power it, you can work your way back to find the short. Maybe someone pulled the fuse for whichever relay it was powered from?
Other option is to go to an Audio/Alarm Shop...most are competent and if your unit is F-ed then a Viper keyless system is pretty cheap with their entry level sh*t.
Update, and more questions:
I bought an OEM remote to program the VIP. After reading the instructions, I decided maybe it'd been programmed one too many times, so I followed instructions to completely wipe the memory of all prior remotes.
Turned around and programmed the new remote. During the entire procedure, the dash light never came on or blinked. Figured I was wasting my time, then....
When I got out of the truck, I clicked the remote, and it blinked the lights twice. No lock. Hit it again, and it blinked the lights once. No lock.
So something is working, but not the whole setup. Anyone have a suggestion on what to check, and where to check it? Appreciate any help y'all can offer!
In reading through much of the Slee materials for troubleshooting, it keeps saying to check the inline fuse for the RS3000. Anyone know where the inline fuse might live?
I’m having the same issue, my alarm & fob were all working perfectly until I took it be serviced, but since the can’t get it to work again, anyone got any good ideas?
That's the first thing I did, second was download the instructing for programming I found here, and tried the sequence a dozen times. I managed to set the alarm off twice, but that was the extent of it - now I have no idea what to do as the instructions don't return the fob to its locking ability.
The RS3000 system can only "remember" 3 remotes. If you're trying the same steps with no result, then try clearing out the memory of the RS3000 and then try to program the remote.
So it turned out that the guys who did the interior detail & carpet cleaning managed to soak the ECU, and that's what fried it, so I had to fit an aftermarket one. That means that I have two Toyota key fobs that I don't need, so if anyone has a need for them just shoot me a PM.
The ECU has nothing to do with door unlock, remote start, alarm or any of that.
Are you 100% sure that your truck has anything to connect a key fob to? It may not as this wasn't a factory thing - but then neither were running boards, roof racks, spoilers...
The ECU DOES control the immobilizer. Something that has gone south on my '99 100 series. Getting i treflashed so I don't run into this problem again, and the signal amplifier on the ignition (the culprit) is out of stock and not being made anymore. Like my damn rear wing. Anyone have one of those?
I am new to the Forum. Today I was able to program 2 replacement Fobs on my 1993 LC FZJ80. The Security ECU is under the drivers seat it looks different than the (1997 green button version in the downloadable manual and previous posts. I removed the seat and on the top of the ECU is a set of labels . There is a small recessed button labeled P- SW (Programable Switch) Now that I am familiar with the ECU I can program without removing seat.
1. Turn on the ignition.
2 Press the P-SW button with a pencil. hold for 3 seconds.
3. Then press the fob top button. (security system sounded once)
4. Turn off ignition
5. Shut door and test fob.
I tried to program 3 fobs. It seems like the 1993 version can only remember 2 fobs. When ever I programmed the 3rd fob it one of the two other fobs lost programming.
