Ok, update.
Things are going slower than originally thought. So far, spent about 30 hours removing the 10 layers of paint off the hood and still not done. Used aircraft paint stripper and that had minimal impact on some areas and did a great job on other areas - the underside of the hood. What was weird is the areas it did penetrate on the top came off in large pieces and snapped - like breaking plastic. Could an epoxy clear coat have been used over the paint? That's the only thing I can think of. I know the stripper did not work on the sealer coat, which was about 7 to 8 layers down. And rather than knocking out the minor dents, just slap bondo on them. Whatever! I'll work them out with my body hammers.
My 50 year old drill and DA sander gave up the ghost, so had to order new ones. Also ordered a bondo buster and that thing is awesome. I have a pretty hefty air compressor, but it can barely keep up with this sander. Probably a 2 stage air compressor would work better. Hey, my tools last me a long time.
Struggling with what to do with the hump on the driver's floor pan and how much to remove in order for the tub to set properly. Took a closer look at the old tranny cover and found some interesting things. Could be repaired, but may not be worth the effort.
Received the LizardSkin and gun, self etching primer (SEM), which I'll use for the underside. Decided to go ahead and prep the underneath once weather warms up and then place the tub on the frame and see what adjustments I'll need to make. I already ground off all unnecessary components on the cowling where the tub will bolt. Considerable rust but nothing serious, so will treat those areas.
Ordered Matrix Ultra High Build 2K primer MP3-HS and activator MA3-HS. Ordered Free Born Red from Tamco - HB Base Series 1:1 mix ratio and reducer slow HR1380. Tammy was a wealth of information. Will order the clear coat from her as well.
Decided to do the inside of the tub with Raptor Liner Tintable and will tint it with the Free Born Red. Saves some frustrations.
Haven't decided on the epoxy seal coat yet. May go with Tamco.
Rear wiring has been completely rewired with new wire and connectors. I decided to just throw the whole rear wiring assembly away and start from scratch. That simplified a whole lot of things. Front has had some rewire done. Anyway, ALL of the weird wiring by the PO has been completely eliminated, plus installed a towing harness. Damn, I actually have backup lights now and the towing lights all work, which the old one did not.
I'm thinking of a way to assemble photos so as not to have a ton of photos posted here. I think I have a solution, so will see. Also, can better describe as to what is going on.
So, until next time, enjoy your FJ's on the road as I'm jealous right now as mine is in pieces.
