Early pickup/hilux and 4-runner tech and classifieds
I recently bought a 1983 Toyota Sr5 short bed 4x4. im not sure what i want to do with it just yet. i need to find patches for the rear wheel wells they are pretty rusty. and i have an exhaust leak out of the manifold. does anyone know where i can find some parts for this old tonka truck? i was also considering an engine swap but im not sure what wil fit in the engine bay. dont get me wrong i love the 22r but its lacking a little in horsepower. any known conversion kits?
4.3 V6 is a common swap as well as a small block Chevy believe it or not.
What are head gasket leak symptoms again for review? Is that a common 22re problem?
Ther can vary depending on where and how bad. Things like oil in the water or water in the oil, water loss from the cooling system, sweet smelling smoke from the exhaust, low power, dead miss, etc. if you suspect you may have a head gasket problem I suggest you stop driving it and do a compression check ASAP. And, no, 22r /22re engines are not common head gasket problems unless the cooling system fails and they are driven hot.
Pickup For sale,
It's my listing, and I am certainly open to offers, all I can say is no. I don't check the board everyday so it is best to respond through the ad.
If it doesn't sell I may sell/trade the upgrades until its more stock, so if you have any interest in the differentials, tires or winch stuff just drop me a line and I'll contact you when I'm ready to part it.
http://northmiss.craigslist.org/cto/4322533239.html
4runner geeks, I got a question. My PS door, the one with two handles, has the regular (front seated
passenger) handle which works but only if you pop the handle open. I partially removed door panel and
when I put pressure on wire that goes from said door handle to door latch it opens correctly. Is there a
screw or way to tighten that wire or arm that runs from handle to latch. This thing still has the plastic on
door interior and I do not want to tear into it if I can not make an adjustment. Thanks.
I busted this removing my intake
manifold:
1989 TOYOTA 4RUNNER 2.4L L4 : Electrical-Switch & Relay : Fuel Injection Thermal / Time Switch
Any on have on sitting on a used manifold they want to sell for a reasonable price?
Plans so far are to stay stock and putt around in it. Unless I through the Marlin 4.7 case and the e lock diffs that I've hoarded up in it....
