Early door rebuild help
Olympia, WA
Website
www.myblueheaven.com
I am trying to take my early style doors apart so that I can fix/replace the regulators and replace all the weather seals and tracks. I have all the screws out and the top part of the doors come loose, but the glass doesn't seem to want to seperate from the regulator.
Any hints on how to seperate them?
Thought i had a answer but after reading maybe not. Check out SOR and see if your missing a bolt, theres some good diagrams. In the solid doors I believe they are in most models just held in by two bolts at the base of the window.
we had the same problem, first pulled the top frame out, and then disassembled with the glass attached to the regulator arm; you'll need a person to hold the stuff while you loosen the nuts/bolts. We did nothing to the triangular windows, left them alone.
forgot to mention: the disassembly is best done laying the better part of the door on a flat surface
Thanks. I got it sorted out eventually. I still have one door to do, but got one completely torn apart tonight. It wasn't actually the regular window that was holding me up, it was the "wing" window. With it closed, there is a flange that prevents the whole thing from coming out of the bottom part of the door. After I found that, the rest came apart with little effort.
Looks like atleast one of my regulators will need replacing. It has a chipped tooth that keeps skipping. Will find out about the other one tomorrow night. I also just ordered all the weather seals I need to rebuild both doors.
I went with SOR for this stuff, the only thing I don't like of what I got from them is the weatherstripping around the whole door. First of all, their glue comes apart easily, I had to use a different glue after a month or so. Secondly, the pattern of the channel is different than stock and that leads to come crunching in the corners, which starts to creak as the rubber gets drier. I basically have to condition it every so often......:rolleyes:
apparently, the around the door weatherstripping can still be had from Toyota. Learned that after the fact.
I ordered the kit from CCOT that does both doors. I did a little digging around and people seem to like that kit, and it does seem to be pretty complete.
I should know tomorrow night if I need a second regulator.
Well you could always build up a bead on the broken tooth then grind it to match the others.
